Nagios crash
Nagios crash
Actually, we have problems with Nagios XI, we have 599 services and 89 hosts and sometimes, the system crashes and we need to reset the operative system. There is one Nagios server in one virtual machine and we have observed that the time access to disk increase in the moment that the system crashes.
Thanks.
Thanks.
meyss
Re: Nagios crash
What configuration do you have for this VM? Could you show us the output of the following commands?
lscpu
free
top
df -hRe: Nagios crash
lscpu:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 4
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 29
Stepping: 1
CPU MHz: 2659.878
BogoMIPS: 5319.75
Hypervisor vendor: VMware
Virtualization type: full
L1d cache: 32K
L1i cache: 32K
L2 cache: 3072K
L3 cache: 16384K
NUMA node0 CPU(s): 0-3
free:
total used free shared buffers cached
Mem: 8053804 6536824 1516980 0 145160 429468
-/+ buffers/cache: 5962196 2091608
Swap: 20964784 0 20964784
top:
top - 08:58:07 up 21:43, 1 user, load average: 2.98, 2.07, 1.73
Tasks: 193 total, 1 running, 192 sleeping, 0 stopped, 0 zombie
Cpu(s): 27.3%us, 15.6%sy, 0.0%ni, 56.9%id, 0.0%wa, 0.0%hi, 0.2%si, 0.0%st
Mem: 8053804k total, 6548364k used, 1505440k free, 145160k buffers
Swap: 20964784k total, 0k used, 20964784k free, 429652k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
21463 apache 20 0 437m 25m 5912 S 20.0 0.3 4:56.41 httpd
31220 apache 20 0 444m 32m 5908 S 15.8 0.4 3:14.60 httpd
10112 mysql 20 0 2196m 84m 6432 S 9.0 1.1 55:20.89 mysqld
20515 apache 20 0 437m 26m 5060 S 8.1 0.3 5:01.28 httpd
23281 apache 20 0 443m 32m 4960 S 6.4 0.4 3:42.16 httpd
50962 apache 20 0 444m 33m 4956 S 5.2 0.4 5:41.25 httpd
56504 apache 20 0 444m 33m 4968 S 5.2 0.4 1:33.93 httpd
17023 nagios 20 0 217m 22m 8212 S 3.2 0.3 0:00.49 php
1559 nagios 20 0 34176 13m 1492 S 1.0 0.2 12:30.95 nagios
16969 root 20 0 15028 1380 980 R 1.0 0.0 0:00.19 top
17034 postgres 20 0 210m 6060 3756 S 1.0 0.1 0:00.05 postmaster
20534 postgres 20 0 210m 6840 4296 S 1.0 0.1 0:16.09 postmaster
17033 postgres 20 0 210m 5700 3504 S 0.6 0.1 0:00.03 postmaster
17036 postgres 20 0 210m 5720 3520 S 0.6 0.1 0:00.04 postmaster
21493 postgres 20 0 210m 6840 4292 S 0.6 0.1 0:16.22 postmaster
23361 postgres 20 0 210m 6844 4292 S 0.6 0.1 0:12.87 postmaster
51287 postgres 20 0 210m 6888 4320 S 0.6 0.1 0:20.37 postmaster
56669 postgres 20 0 210m 6652 4104 S 0.6 0.1 0:05.91 postmaster
20 root 20 0 0 0 0 S 0.3 0.0 1:22.21 events/1
351 root 20 0 0 0 0 S 0.3 0.0 0:05.99 mpt_poll_0
1058 root 20 0 63524 3996 3228 S 0.3 0.0 4:18.95 vmtoolsd
1240 root 16 -4 93200 888 580 S 0.3 0.0 0:26.97 auditd
1378 postgres 20 0 209m 6316 5240 S 0.3 0.1 1:38.67 postmaster
1395 postgres 20 0 173m 1748 540 S 0.3 0.0 1:32.53 postmaster
1482 root 20 0 114m 1232 628 S 0.3 0.0 0:26.39 crond
1509 ajaxterm 20 0 164m 7744 1388 S 0.3 0.1 3:18.26 python
1561 nagios 20 0 10016 948 676 S 0.3 0.0 1:45.59 nagios
1564 nagios 20 0 10016 952 676 S 0.3 0.0 1:44.53 nagios
1566 nagios 20 0 10016 948 676 S 0.3 0.0 1:42.84 nagios
10206 nagios 20 0 50732 2152 992 S 0.3 0.0 3:48.82 ndo2db
17024 nagios 20 0 217m 21m 7744 S 0.3 0.3 0:00.37 php
17027 nagios 20 0 224m 29m 7800 S 0.3 0.4 0:00.73 php
17059 postgres 20 0 210m 6248 3940 S 0.3 0.1 0:00.05 postmaster
17124 nagios 20 0 9196 1180 1016 S 0.3 0.0 0:00.01 sh
31268 postgres 20 0 210m 6704 4152 S 0.3 0.1 0:11.29 postmaster
df -h:
/dev/mapper/VolGroup-lv_root
118G 5.7G 107G 6% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
/dev/sda1 485M 50M 410M 11% /boot
CPU(s): 4
Socket(s): 4
NUMA node(s): 1
CPU family: 6
Model: 29
Stepping: 1
CPU MHz: 2659.878
BogoMIPS: 5319.75
L1d cache: 32K
L1i cache: 32K
L2 cache: 3072K
L3 cache: 16384K
free:
top:
df -h:
118G 5.7G 107G 6% /
meyss
Re: Nagios crash
Can you elaborate on this? Do you see any specific errors in the web UI or in the logs? You can show us screenshots....and sometimes, the system crashes and we need to reset the operative system.
Does the system become totally unusable?
Run the following commands and show the output in code wraps:
tail -100 /usr/local/nagios/var/nagios.log
tail -100 /var/log/httpd/error_log
tail -100 /var/log/mysqld.logBe sure to check out our Knowledgebase for helpful articles and solutions!
Re: Nagios crash
When the system crash, we only can reset the operative system.
[1425388910] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;UNKNOWN;SOFT;1;UNKNOWN - Error: 408 Error while fetching http://10.16.71.21:8080/jolokia/ :
[1425388959] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;2;CRITICAL - Heap-Memory: 97.51% used (997.20 MB / 1022.69 MB)
[1425389018] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;3;CRITICAL - Heap-Memory: 97.66% used (998.75 MB / 1022.69 MB)
[1425389077] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;4;OK - Heap-Memory: 79.25% used (810.47 MB / 1022.69 MB)
[1425389699] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;1;SNMP WARNING - Humedad *61* %
[1425389817] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;2;SNMP WARNING - Humedad *65* %
[1425389935] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;3;SNMP WARNING - Humedad *61* %
[1425390054] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;4;SNMP WARNING - Humedad *63* %
[1425390171] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;HARD;5;SNMP WARNING - Humedad *63* %
[1425390171] SERVICE NOTIFICATION: joseantonio;Sonda STS02 - SA salida escalera;Humedad;WARNING;xi_service_notification_handler;SNMP WARNING - Humedad *63* %
[1425390171] SERVICE NOTIFICATION: joseantonio;Sonda STS02 - SA salida escalera;Humedad;WARNING;notify-service-by-sms;SNMP WARNING - Humedad *63* %
[1425390171] SERVICE NOTIFICATION: carlos;Sonda STS02 - SA salida escalera;Humedad;WARNING;xi_service_notification_handler;SNMP WARNING - Humedad *63* %
[1425390171] SERVICE NOTIFICATION: javierferreiro;Sonda STS02 - SA salida escalera;Humedad;WARNING;xi_service_notification_handler;SNMP WARNING - Humedad *63* %
[1425390171] SERVICE NOTIFICATION: laura;Sonda STS02 - SA salida escalera;Humedad;WARNING;xi_service_notification_handler;SNMP WARNING - Humedad *63* %
[1425390171] SERVICE NOTIFICATION: susana;Sonda STS02 - SA salida escalera;Humedad;WARNING;xi_service_notification_handler;SNMP WARNING - Humedad *63* %
[1425390270] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;WARNING;SOFT;1;WARNING - Heap-Memory: 86.93% used (888.32 MB / 1021.88 MB)
[1425390327] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;2;CRITICAL - Heap-Memory: 93.33% used (953.73 MB / 1021.88 MB)
[1425390385] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;3;CRITICAL - Heap-Memory: 91.30% used (932.94 MB / 1021.88 MB)
[1425390444] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;4;CRITICAL - Heap-Memory: 97.25% used (993.79 MB / 1021.88 MB)
[1425390503] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;5;OK - Heap-Memory: 68.55% used (697.44 MB / 1017.44 MB)
[1425391070] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;OK;HARD;5;SNMP OK - Humedad 55 %
[1425391070] SERVICE NOTIFICATION: joseantonio;Sonda STS02 - SA salida escalera;Humedad;OK;xi_service_notification_handler;SNMP OK - Humedad 55 %
[1425391070] SERVICE NOTIFICATION: joseantonio;Sonda STS02 - SA salida escalera;Humedad;OK;notify-service-by-sms;SNMP OK - Humedad 55 %
[1425391070] SERVICE NOTIFICATION: carlos;Sonda STS02 - SA salida escalera;Humedad;OK;xi_service_notification_handler;SNMP OK - Humedad 55 %
[1425391070] SERVICE NOTIFICATION: javierferreiro;Sonda STS02 - SA salida escalera;Humedad;OK;xi_service_notification_handler;SNMP OK - Humedad 55 %
[1425391070] SERVICE NOTIFICATION: laura;Sonda STS02 - SA salida escalera;Humedad;OK;xi_service_notification_handler;SNMP OK - Humedad 55 %
[1425391070] SERVICE NOTIFICATION: susana;Sonda STS02 - SA salida escalera;Humedad;OK;xi_service_notification_handler;SNMP OK - Humedad 55 %
[1425392121] Auto-save of retention data completed successfully.
[1425392331] SERVICE ALERT: oracle tns preproduccion;Oracle - Connection Time - PRE1_NODO2;WARNING;SOFT;1;WARNING - 1.14 seconds to connect as PRUE_CONEX
[1425392389] SERVICE ALERT: oracle tns preproduccion;Oracle - Connection Time - PRE1_NODO2;OK;SOFT;2;OK - 0.14 seconds to connect as PRUE_CONEX
[1425393187] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;1;CRITICAL - Heap-Memory: 98.08% used (997.91 MB / 1017.44 MB)
[1425393250] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;2;OK - Heap-Memory: 69.08% used (702.83 MB / 1017.44 MB)
[1425394448] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;WARNING;SOFT;1;WARNING - Heap-Memory: 80.28% used (816.84 MB / 1017.44 MB)
[1425394503] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;2;OK - Heap-Memory: 72.61% used (738.78 MB / 1017.44 MB)
[1425394663] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;1;SNMP WARNING - Humedad *65* %
[1425394782] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;2;SNMP WARNING - Humedad *61* %
[1425394786] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP gesarty;CRITICAL;SOFT;1;CRITICAL - Socket timeout after 10 seconds
[1425394837] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP gesarty;OK;SOFT;2;HTTP OK: HTTP/1.1 200 OK - 1802 bytes in 3.695 second response time
[1425394900] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;3;SNMP WARNING - Humedad *62* %
[1425395019] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;4;SNMP WARNING - Humedad *63* %
[1425395137] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;OK;SOFT;5;SNMP OK - Humedad 57 %
[1425395721] Auto-save of retention data completed successfully.
[1425396743] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP artifactory;CRITICAL;SOFT;1;CRITICAL - Socket timeout after 10 seconds
[1425396800] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP artifactory;OK;SOFT;2;HTTP OK: HTTP/1.1 302 Movido temporálmente - 497 bytes in 8.290 second response time
[1425396882] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;WARNING;SOFT;1;WARNING - Heap-Memory: 85.62% used (871.01 MB / 1017.31 MB)
[1425396931] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP gesarty;CRITICAL;SOFT;1;CRITICAL - Socket timeout after 10 seconds
[1425396945] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;2;OK - Heap-Memory: 69.36% used (705.66 MB / 1017.31 MB)
[1425396984] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP gesarty;OK;SOFT;2;HTTP OK: HTTP/1.1 200 OK - 1802 bytes in 3.233 second response time
[1425397100] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP artifactory;CRITICAL;SOFT;1;CRITICAL - Socket timeout after 10 seconds
[1425397149] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP artifactory;OK;SOFT;2;HTTP OK: HTTP/1.1 302 Movido temporálmente - 497 bytes in 0.177 second response time
[1425397189] wproc: Core Worker 1565: job 36253 (pid=36163) timed out. Killing it
[1425397189] wproc: CHECK job 36253 from worker Core Worker 1565 timed out after 60.01s
[1425397189] wproc: host=spirit; service=Ironport - IronPort Anti-Spam License;
[1425397189] wproc: early_timeout=1; exited_ok=0; wait_status=0; error_code=62;
[1425397189] Warning: Check of service 'Ironport - IronPort Anti-Spam License' on host 'spirit' timed out after 60.008s!
[1425397189] SERVICE ALERT: spirit;Ironport - IronPort Anti-Spam License;CRITICAL;SOFT;1;(Service check timed out after 60.01 seconds)
[1425397189] wproc: Core Worker 1565: job 36253 (pid=36163): Dormant child reaped
[1425397193] SERVICE ALERT: spirit;Ironport - CPU Usage;CRITICAL;SOFT;1;CPU CRITICAL: 97%
[1425397193] SERVICE ALERT: spirit;Ironport - IronPort Anti-Spam License;OK;SOFT;2;IronPort Anti-Spam License OK: 33 days remaining
[1425397228] SERVICE ALERT: spirit;Ironport - CPU Usage;CRITICAL;SOFT;2;CPU CRITICAL: 97%
[1425397238] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;1;CRITICAL - Heap-Memory: 99.29% used (1013.27 MB / 1020.50 MB)
[1425397285] SERVICE ALERT: spirit;Ironport - CPU Usage;OK;SOFT;3;CPU OK: 14%
[1425397305] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;2;OK - Heap-Memory: 67.35% used (687.94 MB / 1021.44 MB)
[1425397595] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;1;CRITICAL - Heap-Memory: 92.57% used (945.12 MB / 1020.94 MB)
[1425397652] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;2;OK - Heap-Memory: 72.31% used (738.23 MB / 1020.94 MB)
[1425397841] SERVICE ALERT: vmxapmp.trabajo.dom;AJP - Threads en uso;UNKNOWN;SOFT;1;UNKNOWN - Error: 408 Error while fetching http://10.16.71.21:8080/jolokia/ :
[1425397890] SERVICE ALERT: vmxapmp.trabajo.dom;AJP - Threads en uso;OK;SOFT;2;OK - Connector ajp*8009 : 0.00% used (00 / 200)
[1425398249] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;1;CRITICAL - Heap-Memory: 92.21% used (941.05 MB / 1020.56 MB)
[1425398315] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;2;OK - Heap-Memory: 69.99% used (714.34 MB / 1020.56 MB)
[1425399204] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;1;CRITICAL - Heap-Memory: 90.34% used (921.99 MB / 1020.56 MB)
[1425399246] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP artifactory;CRITICAL;SOFT;1;CRITICAL - Socket timeout after 10 seconds
[1425399264] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;2;OK - Heap-Memory: 69.29% used (707.19 MB / 1020.56 MB)
[1425399294] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP artifactory;OK;SOFT;2;HTTP OK: HTTP/1.1 302 Movido temporálmente - 497 bytes in 0.186 second response time
[1425399321] Auto-save of retention data completed successfully.
[1425399562] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;WARNING;SOFT;1;WARNING - Heap-Memory: 89.78% used (916.31 MB / 1020.56 MB)
[1425399620] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;2;CRITICAL - Heap-Memory: 94.16% used (960.99 MB / 1020.56 MB)
[1425399630] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;1;SNMP WARNING - Humedad *64* %
[1425399680] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;3;CRITICAL - Heap-Memory: 96.93% used (989.27 MB / 1020.56 MB)
[1425399739] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;4;CRITICAL - Heap-Memory: 97.89% used (998.99 MB / 1020.56 MB)
[1425399749] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;OK;SOFT;2;SNMP OK - Humedad 59 %
[1425399802] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;5;OK - Heap-Memory: 69.61% used (710.42 MB / 1020.56 MB)
[1425401289] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;WARNING;SOFT;1;WARNING - Heap-Memory: 87.47% used (892.76 MB / 1020.69 MB)
[1425401347] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;2;CRITICAL - Heap-Memory: 95.30% used (972.72 MB / 1020.69 MB)
[1425401406] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;3;OK - Heap-Memory: 74.16% used (756.92 MB / 1020.69 MB)
[1425401621] SERVICE ALERT: vmexphcintra63.trabajo.dom;Jboss - Memoria Java 8080;UNKNOWN;SOFT;1;UNKNOWN - Error: 408 Error while fetching http://10.16.70.125:8080/jolokia/ :
[1425401668] SERVICE ALERT: vmexphcintra63.trabajo.dom;Jboss - Memoria Java 8080;OK;SOFT;2;OK - Heap-Memory: 44.26% used (1.56 GB / 3.51 GB)
[1425401704] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;CRITICAL;SOFT;1;CRITICAL - Heap-Memory: 94.80% used (966.59 MB / 1019.62 MB)
[1425401762] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;WARNING;SOFT;2;WARNING - Heap-Memory: 88.10% used (898.36 MB / 1019.75 MB)
[1425401819] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;WARNING;SOFT;3;WARNING - Heap-Memory: 81.09% used (827.24 MB / 1020.12 MB)
[1425401878] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;4;OK - Heap-Memory: 64.00% used (653.45 MB / 1020.94 MB)
[1425402443] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;1;SNMP WARNING - Humedad *65* %
[1425402561] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;2;SNMP WARNING - Humedad *61* %
[1425402680] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;3;SNMP WARNING - Humedad *62* %
[1425402799] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;WARNING;SOFT;4;SNMP WARNING - Humedad *64* %
[1425402917] SERVICE ALERT: Sonda STS02 - SA salida escalera;Humedad;OK;SOFT;5;SNMP OK - Humedad 59 %
[1425402921] Auto-save of retention data completed successfully.
[1425403121] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP jira;CRITICAL;SOFT;1;CRITICAL - Socket timeout after 10 seconds
[1425403170] SERVICE ALERT: vmxapmp.trabajo.dom;HTTP jira;OK;SOFT;2;HTTP OK: HTTP/1.1 200 OK - 28553 bytes in 0.080 second response time
[1425403967] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;WARNING;SOFT;1;WARNING - Heap-Memory: 84.27% used (857.96 MB / 1018.12 MB)
[1425404025] SERVICE ALERT: vmxapmp.trabajo.dom;Tomcat - Memoria Java;OK;SOFT;2;OK - Heap-Memory: 79.15% used (805.83 MB / 1018.12 MB)
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: max_latency in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 109, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: avg_latency in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 110, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: min_execution_time in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 111, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: max_execution_time in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 112, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: avg_execution_time in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 113, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: min_latency in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 118, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: max_latency in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 119, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: avg_latency in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 120, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: min_execution_time in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 121, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: max_execution_time in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 122, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: avg_execution_time in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 123, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:34:51 2015] [error] [client 10.16.8.211] PHP Notice: Undefined index: min_latency in /usr/local/nagiosxi/html/includes/utils-xmlsysstat.inc.php on line 108, referer: http://10.16.70.238/nagiosxi/index.php?
[Mon Mar 02 11:35:16 2015] [error] [client 10.16.13.178] PHP Notice: Trying to get property of non-object in /usr/local/nagiosxi/html/includes/components/xicore/ajaxhelpers-servicestatus.inc.php on line 425, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?show=services
[Mon Mar 02 11:35:16 2015] [error] [client 10.16.13.178] PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/xicore/ajaxhelpers-servicestatus.inc.php on line 425, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?show=services
[Mon Mar 02 11:35:47 2015] [error] [client 10.16.13.178] PHP Notice: Trying to get property of non-object in /usr/local/nagiosxi/html/includes/components/xicore/ajaxhelpers-servicestatus.inc.php on line 425, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?show=services
[Mon Mar 02 11:35:47 2015] [error] [client 10.16.13.178] PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/xicore/ajaxhelpers-servicestatus.inc.php on line 425, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?show=services
[Mon Mar 02 11:36:53 2015] [error] [client ::1] PHP Notice: Undefined index: ccm_language in /usr/local/nagiosxi/html/includes/components/ccm/includes/common_functions.inc.php on line 710
[Mon Mar 02 11:36:53 2015] [error] [client ::1] PHP Notice: Undefined index: language in /usr/local/nagiosxi/html/includes/components/ccm/includes/common_functions.inc.php on line 710
[Mon Mar 02 11:36:56 2015] [error] [client ::1] PHP Notice: Undefined index: ccm_language in /usr/local/nagiosxi/html/includes/components/ccm/includes/common_functions.inc.php on line 710
[Mon Mar 02 11:36:56 2015] [error] [client ::1] PHP Notice: Undefined index: language in /usr/local/nagiosxi/html/includes/components/ccm/includes/common_functions.inc.php on line 710
[Mon Mar 02 12:50:40 2015] [error] [client 10.16.10.44] PHP Warning: simplexml_load_file(): /usr/local/nagios/share/perfdata/vmxapmp.trabajo.dom/HTTP_artifactory.xml:55: parser error : Input is not proper UTF-8, indicate encoding !\nBytes: 0xE1 0x6C 0x6D 0x65 in /usr/local/nagiosxi/html/includes/components/capacityplanning/capacityplanning.inc.php on line 227, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?show=services&servicestatustypes=16&serviceattr=10&hoststatustypes=3
[Mon Mar 02 12:50:40 2015] [error] [client 10.16.10.44] PHP Warning: simplexml_load_file(): <NAGIOS_SERVICEOUTPUT>HTTP OK: HTTP/1.1 302 Movido tempor\xe1lmente - 497 bytes i in /usr/local/nagiosxi/html/includes/components/capacityplanning/capacityplanning.inc.php on line 227, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?show=services&servicestatustypes=16&serviceattr=10&hoststatustypes=3
[Mon Mar 02 12:50:40 2015] [error] [client 10.16.10.44] PHP Warning: simplexml_load_file(): ^ in /usr/local/nagiosxi/html/includes/components/capacityplanning/capacityplanning.inc.php on line 227, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?show=services&servicestatustypes=16&serviceattr=10&hoststatustypes=3
[Tue Mar 03 12:59:16 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/xi-index.php
[Tue Mar 03 12:59:16 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/xi-index.php
[Tue Mar 03 12:59:25 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/?cmd=view&type=host
[Tue Mar 03 12:59:25 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/?cmd=view&type=host
[Tue Mar 03 12:59:38 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/xi-index.php
[Tue Mar 03 12:59:38 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/xi-index.php
[Tue Mar 03 12:59:53 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/?cmd=view&type=service
[Tue Mar 03 12:59:53 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/?cmd=view&type=service
[Tue Mar 03 13:00:48 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:00:48 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:02:59 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:02:59 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:04:00 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:04:00 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:04:16 2015] [error] [client 10.16.10.123] PHP Notice: Undefined index: template_name in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/common_settings.php on line 53, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:04:56 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:04:56 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:05:14 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:05:14 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:06:30 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:06:30 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:06:37 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:06:37 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:09:12 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:09:12 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:12:51 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:12:51 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:12:55 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:12:55 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:13:26 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:13:26 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:14:43 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:14:43 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:16:12 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:16:12 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:16:34 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:16:34 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:18:00 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:18:00 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:18:16 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:18:16 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:20:07 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:20:07 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:22:35 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:22:35 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:24:15 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:24:15 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:25:00 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:25:00 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:34:43 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:34:43 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:37:27 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/xi-index.php
[Tue Mar 03 13:37:27 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/xi-index.php
[Tue Mar 03 13:37:31 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/?cmd=view&type=host
[Tue Mar 03 13:37:31 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/?cmd=view&type=host
[Tue Mar 03 13:37:56 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/xi-index.php
[Tue Mar 03 13:37:56 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/xi-index.php
[Tue Mar 03 13:38:04 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/?cmd=view&type=service
[Tue Mar 03 13:38:04 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/?cmd=view&type=service
[Tue Mar 03 13:43:00 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:43:00 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:44:01 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: ac_needed_js_inject in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 176, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 13:44:01 2015] [error] [client 10.16.10.123] PHP Notice: Undefined variable: sync_table_status in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/ccm_table.php on line 196, referer: http://10.16.70.238/nagiosxi/includes/components/ccm/index.php
[Tue Mar 03 14:17:52 2015] [error] [client 10.16.2.252] PHP Warning: simplexml_load_file(): /usr/local/nagios/share/perfdata/vmxapmp.trabajo.dom/HTTP_artifactory.xml:55: parser error : Input is not proper UTF-8, indicate encoding !\nBytes: 0xE1 0x6C 0x6D 0x65 in /usr/local/nagiosxi/html/includes/components/capacityplanning/capacityplanning.inc.php on line 227, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?&show=services&hoststatustypes=0&servicestatustypes=16
[Tue Mar 03 14:17:52 2015] [error] [client 10.16.2.252] PHP Warning: simplexml_load_file(): <NAGIOS_SERVICEOUTPUT>HTTP OK: HTTP/1.1 302 Movido tempor\xe1lmente - 497 bytes i in /usr/local/nagiosxi/html/includes/components/capacityplanning/capacityplanning.inc.php on line 227, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?&show=services&hoststatustypes=0&servicestatustypes=16
[Tue Mar 03 14:17:52 2015] [error] [client 10.16.2.252] PHP Warning: simplexml_load_file(): ^ in /usr/local/nagiosxi/html/includes/components/capacityplanning/capacityplanning.inc.php on line 227, referer: http://10.16.70.238/nagiosxi/includes/components/xicore/status.php?&show=services&hoststatustypes=0&servicestatustypes=16
150225 14:27:14 [Warning] /usr/libexec/mysqld: Forcing close of thread 3437 user: 'ndoutils'
150225 14:27:20 [Warning] /usr/libexec/mysqld: Forcing close of thread 3436 user: 'nagiosql'
150225 14:27:22 [Warning] /usr/libexec/mysqld: Forcing close of thread 3435 user: 'nagiosql'
150225 14:27:22 [Warning] /usr/libexec/mysqld: Forcing close of thread 3434 user: 'nagiosql'
150225 14:27:22 [Warning] /usr/libexec/mysqld: Forcing close of thread 3433 user: 'nagiosql'
150225 14:27:22 [Warning] /usr/libexec/mysqld: Forcing close of thread 3432 user: 'nagiosql'
150225 14:27:22 [Warning] /usr/libexec/mysqld: Forcing close of thread 3431 user: 'ndoutils'
150225 14:27:22 [Warning] /usr/libexec/mysqld: Forcing close of thread 3430 user: 'ndoutils'
150225 14:27:22 [Warning] /usr/libexec/mysqld: Forcing close of thread 3429 user: 'ndoutils'
150225 14:27:22 [Warning] /usr/libexec/mysqld: Forcing close of thread 3428 user: 'ndoutils'
150225 14:28:02 [Warning] /usr/libexec/mysqld: Forcing close of thread 3427 user: 'ndoutils'
150225 14:29:00 [Warning] /usr/libexec/mysqld: Forcing close of thread 3426 user: 'nagiosql'
150225 14:29:18 [Warning] /usr/libexec/mysqld: Forcing close of thread 3372 user: 'nagiosql'
150225 14:38:08 InnoDB: Starting shutdown...
150225 14:46:17 InnoDB: Shutdown completed; log sequence number 0 44233
150225 14:46:43 [Note] /usr/libexec/mysqld: Shutdown complete
150225 14:48:59 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
150225 15:13:57 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
150225 15:13:57 InnoDB: Initializing buffer pool, size = 8.0M
150225 15:13:57 InnoDB: Completed initialization of buffer pool
150225 15:13:57 InnoDB: Started; log sequence number 0 44233
150225 15:13:57 [Note] Event Scheduler: Loaded 0 events
150225 15:13:57 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.71' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distribution
150226 12:41:19 [Note] /usr/libexec/mysqld: Normal shutdown
150226 12:42:11 [Note] Event Scheduler: Purging the queue. 0 events
150226 12:42:35 [Warning] /usr/libexec/mysqld: Forcing close of thread 28333 user: 'ndoutils'
150226 12:42:36 [Warning] /usr/libexec/mysqld: Forcing close of thread 28329 user: 'nagiosql'
150226 12:42:38 [Warning] /usr/libexec/mysqld: Forcing close of thread 28328 user: 'ndoutils'
150226 12:45:21 [Warning] /usr/libexec/mysqld: Forcing close of thread 28327 user: 'nagiosql'
150226 12:48:24 [Warning] /usr/libexec/mysqld: Forcing close of thread 28320 user: 'nagiosql'
150226 12:51:13 [Warning] /usr/libexec/mysqld: Forcing close of thread 28308 user: 'nagiosql'
150226 12:51:15 [Warning] /usr/libexec/mysqld: Forcing close of thread 28266 user: 'nagiosql'
150226 12:51:26 [Warning] /usr/libexec/mysqld: Forcing close of thread 28258 user: 'nagiosql'
150226 12:51:26 [Warning] /usr/libexec/mysqld: Forcing close of thread 28255 user: 'nagiosql'
150226 12:51:26 [Warning] /usr/libexec/mysqld: Forcing close of thread 28237 user: 'nagiosql'
150226 12:51:26 [Warning] /usr/libexec/mysqld: Forcing close of thread 28232 user: 'nagiosql'
150226 12:51:26 [Warning] /usr/libexec/mysqld: Forcing close of thread 28226 user: 'nagiosql'
150226 13:04:30 InnoDB: Starting shutdown...
150226 13:10:10 InnoDB: Shutdown completed; log sequence number 0 44233
150226 13:10:52 [Note] /usr/libexec/mysqld: Shutdown complete
150226 13:12:48 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
150226 14:18:23 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
150226 14:18:24 InnoDB: Initializing buffer pool, size = 8.0M
150226 14:18:24 InnoDB: Completed initialization of buffer pool
150226 14:18:25 InnoDB: Started; log sequence number 0 44233
150226 14:18:25 [Note] Event Scheduler: Loaded 0 events
150226 14:18:25 [Note] /usr/libexec/mysqld: ready for connections.
150227 8:38:15 [Note] /usr/libexec/mysqld: Normal shutdown
150227 8:38:15 [Note] Event Scheduler: Purging the queue. 0 events
150227 8:38:15 InnoDB: Starting shutdown...
150227 8:38:20 InnoDB: Shutdown completed; log sequence number 0 44233
150227 8:38:20 [Note] /usr/libexec/mysqld: Shutdown complete
150227 08:38:21 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
150227 08:40:10 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
150227 8:40:12 InnoDB: Initializing buffer pool, size = 8.0M
150227 8:40:12 InnoDB: Completed initialization of buffer pool
150227 8:40:13 InnoDB: Started; log sequence number 0 44233
150227 8:40:13 [Note] Event Scheduler: Loaded 0 events
150227 8:40:13 [Note] /usr/libexec/mysqld: ready for connections.
150302 11:34:03 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
150302 11:34:03 InnoDB: Initializing buffer pool, size = 8.0M
150302 11:34:03 InnoDB: Completed initialization of buffer pool
150302 11:34:03 InnoDB: Started; log sequence number 0 44233
150302 11:34:03 [Note] Event Scheduler: Loaded 0 events
150302 11:34:03 [Note] /usr/libexec/mysqld: ready for connections.
meyss
Re: Nagios crash
What version of XI are you running?
Are there other VM's on the system that could be monopolizing the disk I/O?
Have you tried restarting the mysqld to see if this is going to fix the issue?
BTW, is mysql database offloaded to a remote server?
service mysqld restartBe sure to check out our Knowledgebase for helpful articles and solutions!
Re: Nagios crash
Our version is Nagios XI 2014R2.5. We can not install the last version because Nagios crash too.
Our mysql database is in the same server. We thought to use a new server for the database. In this case, what are the hardware requeriment for the database server? It could be the solution to my problem?
I don't think that there are another machines with high I/O disk, only nagios server, but we monitor it.
Thanks.
Thanks.
meyss
Re: Nagios crash
Can you please clarify? What symptoms or behavior are you experiencing when nagios "crashes"?meyss wrote: the system crashes and we need to reset the operative system.
Re: Nagios crash
The nagios interface web no response and we restart the server in the visare sistema because we can not connect to the server.
meyss
Re: Nagios crash
Can you connect to the server with SSH?
