check_nt -> wrong -l argument
egburgoa
Post by egburgoa »
Hello....
I try to chek the disk "c" with the command from the shell
/usr/lib/nagios/plugins/check_nt -H xxx.xxx.xxx.xxx -v USEDDISKSPACE -p 12489 -l c
and works fine....but the service defined in nagios when execute the command return the error "wrong -l argument"
This is the definition of service is
hostgroup_name SERVERS
service_description Drive C
check_command check_nt!USEDDISKSPACE!-l c
normal_check_interval 10
retry_check_interval 360
notification_interval 720
notification_options w,c
The version of Nagios core is 3.2.1
Why the nagios send the error ??
Thanks.
Emilio G. Burgoa
[email protected]
San Juan - Argentina
SDohmen
Re: check_nt -> wrong -l argument
Post by SDohmen »
I had the same problem on several nagios installations. What i did to resolve the problem is the following:
Open nt.cfg (/etc/nagios-plugins/config/nt.cfg)
The first check_nt command should say:
command_name check_nt
command_line /usr/lib/nagios/plugins/check_nt -H '$HOSTADDRESS$' -v '$ARG1$'
Change the command_line too:
command_line /usr/lib/nagios/plugins/check_nt -H '$HOSTADDRESS$' -p 12489 -v '$ARG1$' '$ARG2$'
Save and reload nagios. That should fix the problem (at least it did for me)
