NLS Stops Intermittently
Once in a while NLS will stop responding and won't respond to logon requests either. Usually restarting the elasticsearch service will resolve the issue. However today when I tried restarting the service I got the following message:
[root@nagiosls ~]# service elasticsearch restart
Stopping elasticsearch: [ OK ]
Starting elasticsearch: [ OK ]
[root@nagiosls ~]# OpenJDK 64-Bit Server VM warning: Insufficient space for shared memory file:
11743
Try using the -Djava.io.tmpdir= option to select an alternate temp location.
{1.3.2}: pid Failed ...
- IOException[No space left on device]
java.io.IOException: No space left on device
at java.io.FileOutputStream.writeBytes(Native Method)
at java.io.FileOutputStream.write(FileOutputStream.java:325)
at org.elasticsearch.bootstrap.Bootstrap.main(Bootstrap.java:157)
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:32)
Intel Quad core 3.2Ghz
8GB RAM
Any suggestions?
11743
8GB RAM
Any suggestions?
Re: NLS Stops Intermittently
Ok, so I should have looked deeper prior to the post. The issue is I've ran out of disk space. I thought I had the Backup settings configured properly but I guess I don't.
What are the recommendations for freeing up disk space?
Thanks.
Thanks.
Please access the page at "Administration > Backup & Maintenance" and review the options there. Ensure that you have an off-site backup repository so that your backups aren't using local disk space. The most relevant setting on this page for you will be 'Delete indexes older than *', which you can set to a value of your choice. After setting that value, click 'Command Subsystem' and select "Edit" next to "backup_maintenance" - make the next run time 'Now' and NLS will begin the process of removing your old indexes.
Ok. Due to insufficient disk space I can't get Elasticsearch to stay running thus not allowing me to logon to the Web Interface. What I can delete or remove safely to get some disk space?
Please post the output of the command below.
ls -lhrt /store/backups/nagioslogserverRe: NLS Stops Intermittently
[root@nagiosls ~]# ls -lhrt /store/backups/nagioslogserver
total 0
total 0
It appears that you have run out of space in the tmpfs share memory filesystem. Could you show us the output of the following commands:OpenJDK 64-Bit Server VM warning: Insufficient space for shared memory file:
df -h
cat /etc/fstabRe: NLS Stops Intermittently
[root@nagiosls ~]# df -h
/dev/mapper/vg_nagiosls-lv_root
50G 47G 13M 100% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
/dev/sda1 477M 68M 384M 15% /boot
/dev/mapper/vg_nagiosls-lv_home
401G 71M 381G 1% /home
[root@nagiosls ~]# cat /etc/fstab
# /etc/fstab
# Created by anaconda on Mon Feb 2 14:34:57 2015
# Accessible filesystems, by reference, are maintained under '/dev/disk'
# See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info
/dev/mapper/vg_nagiosls-lv_root / ext4 defaults 1 1
UUID=ed86a6aa-c3ef-4c1c-a541-4b6c3d46edb7 /boot ext4 defaults 1 2
/dev/mapper/vg_nagiosls-lv_home /home ext4 defaults 1 2
/dev/mapper/vg_nagiosls-lv_swap swap swap defaults 0 0
tmpfs /dev/shm tmpfs defaults 0 0
devpts /dev/pts devpts gid=5,mode=620 0 0
sysfs /sys sysfs defaults 0 0
proc /proc proc defaults 0 0
50G 47G 13M 100% /
# /etc/fstab
It looks like there is a lot of free space in your home volume. A good solution would be to resize your volumes so that /dev/mapper/vg_nagiosls-lv_home is reduced by ~300GB, and /dev/mapper/vg_nagiosls-lv_root is increased by the same amount.34Bearman wrote: 401G 71M 381G 1% /home
To see your logical volumes, you can run:
lvscanBe aware that you should shrink the filesystem size of the home directory before you reduce the volume size.
To increase the size of a logical volume (your root directory), follow these instructions:
https://access.redhat.com/documentation ... xtend.html
To reduce the size of a logical volume (your home directory), follow these instructions:
https://access.redhat.com/documentation ... educe.html
Example commands-
Unmount the home directory:
umount /dev/myvg/homevolCode: Select all
resize2fs -p /dev/myvg/homevol 100GCode: Select all
lvreduce -L 100G /dev/myvg/homevolCode: Select all
lvextend -L+300G /dev/myvg/rootvolCode: Select all
umount /dev/myvg/rootvolCode: Select all
resize2fs /dev/myvg/rootvolRe: NLS Stops Intermittently
Thanks. It's good now. Please close this thread.
