Nagios XI - Disabling Notification and Alerts
annbingle
Post by annbingle »
Good day!
We need to disable all alerts and notifications for everything we monitor in Nagios Xi for a specific period of time. We know how to individually but for all, can you help us?
Thanks and have a great day!
Ann :?:
cmerchant
Re: Nagios XI - Disabling Notification and Alerts
Post by cmerchant »
Go into the Process info in the UI and disable it there,
XI --> Admin --> System Information --> Monitoring Engine Status --> Monitoring Engine Process --> click on green colored icon right of Notifications to disable.
The status icon will change to Red to indicate disabled. Click on the same icon to enable notifications.
There is also an external command facility to issue the command through a script via cron or CLI.
http://nagios.sourceforge.net/docs/nagi ... mands.html
http://www.nagios.org/developerinfo/externalcommands/
ssax
Dreams In Code
Post by ssax »
You can also edit the file below and set enable_notifications=0 and restart nagios.
/usr/local/nagios/etc/nagios.cfg
annbingle
Post by annbingle »
Thank you both so much for your response, I appreciate it.
Have a great day!
Ann :D
rajasegar
Post by rajasegar »
How do you disable all monitoring for all hosts from the command line?
How to schedule downtime for all hosts and services from the command line?
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
Post by Box293 »
rajasegar wrote:How do you disable all monitoring for all hosts from the command line?
Using the command pipe (nagios.cmd)
Click on
STOP_EXECUTING_HOST_CHECKS
or
SCHEDULE_HOSTGROUP_HOST_DOWNTIME (put all the hosts in a hostgroup)
for examples
http://old.nagios.org/developerinfo/ext ... ndlist.php
rajasegar
Post by rajasegar »
Click on
or
for examples
Ok. Thanks
RHEL 6 & 7
ssax
Dreams In Code
Post by ssax »
OP, can we mark this as resolved and lock the topic?
rajasegar
Post by rajasegar »
ssax wrote:OP, can we mark this as resolved and lock the topic?
Ok. Please close this case
RHEL 6 & 7
