Issue with check_logfiles plugin
RIDS_I2MP
Post by RIDS_I2MP »
Hi team,
we are using check_logfiles plugin to look for some pattern in our log files in few application servers, tough it was working fine till early this week on all the servers, we have had an issue on 1 server. When a check is executed we see the message 'CHECK_NRPE: Socket timeout after 30 seconds' on the nagios console. We have logged into the application server and run the plugin to check a pattern as there we get the below message.
[nagios@localhost libexec]$ ./check_logfiles --logfile=logfile path --criticalpattern=string
Argument "           'runcount' => 38544," isn't numeric in localtime at ./check_logfiles line 2966.
I have tried re-compiling the plugin from source and also replacing it with the plugin from a different server where it was working fine with no success. 1 thing I observed is the tmp files created in /tmp are not getting created now. Please help
Thanks & Regards,
I2MP Team.
abrist
Red Shirt
Re: Issue with check_logfiles plugin
Post by abrist »
Can you post a link to this plugin?
What OS/version is the plugin running on?
I want to test this plugin myself.
RIDS_I2MP
Post by RIDS_I2MP »
Link for the plugin check_logfiles - http://labs.consol.de/lang/en/nagios/check_logfiles/
OS Version - Linux 2.6.18-371.el5 #1 SMP Thu Sep 5 21:21:44 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
Thanks & Regards,
I2MP Team.
ssax
Dreams In Code
Post by ssax »
Looks like it may be an issue with the contents of one of your seekfiles that check_logfiles uses.
Look in the directory below for check_logfiles._log_file_path and/or check_logfiles._log_file_path.seek and compare it to one on the working machine.
/var/tmp/check_logfiles/check_logfiles
Let us know what you find.
