NNA Version 2R1.0 Queries and Reports problems
martins719
Post by martins719 »
I have 5 source devices in the NNA new version with data in the Dashboards but is working reports and queries only to 1 device.
martins719
Re: NNA Version 2R1.0 Queries and Reports problems
Only to better detail, only Queries and Reports from Cisco ASA Netflow is not working.
I have graph informations and files in the flows directory.
Can you show us a screenshot of the error that you are getting? Run the following commands from the command line on the Nagios NA server and show us the output:
date
file /etc/localtime
grep "date.timezone =" /etc/php.ini
Can you verify the the time on the Cisco device and your workstation is synced to the NNA time?
martins719
Firewall time - fw01-it-spo# sh clock - 08:32:01.256 BR Fri Mar 6 2015
Nagios NA Time - [root@localhost ~]# date Fri Mar 6 08:33:32 BRT 2015
[root@localhost ~]# file /etc/localtime
/etc/localtime: symbolic link to `/usr/share/zoneinfo/America/Sao_Paulo'
[root@localhost ~]# grep "date.timezone =" /etc/php.ini
date.timezone = America/Sao_Paulo
This was working with old version.
The problem that I can see in the flows files there are some lines with mistake date 1969-12-31 21:00:00.749 . I don´t know if the firewall is sending mistake or Nagios NA nfcapd is not working well.
nfdump -r nfcapd.201503060830
1969-12-31 21:00:00.749 -0.749 UDP 172.20.8.75:17500 -> 172.20.8.255:17500 0 0 1
2015-03-06 08:30:10.891 0.000 ICMP 192.168.0.210:0 -> 172.20.3.181:0.0 0 0 1
2015-03-06 08:30:10.891 0.000 ICMP 192.168.0.210:0 -> 172.20.3.181:0.0 0 107 1
1969-12-31 21:00:00.405 -0.405 UDP 172.20.8.75:63993 -> 172.20.3.16:161 0 0 1
2015-03-06 08:35:06.934 0.000 UDP 172.20.1.132:57258 -> 8.8.8.8:53 0 0 1
2015-03-06 08:35:06.984 0.000 UDP 172.20.1.132:57145 -> 8.8.8.8:53 0 0 1
2015-03-06 08:35:06.934 0.000 UDP 172.20.1.132:57258 -> 8.8.8.8:53 0 45 1
Thanks a lot
martins719
Follow the errors files..
Can you run the following command on the NNA box for a while (until you see useful output) and post the output?
tcpdump -i eth0 src 172.20.8.75
Note: change the name of the interface if you need to.
Also, let's see the output of this:
cat /etc/sysconfig/clock
martins719
[root@localhost flows]# cat /etc/sysconfig/clock
ZONE="America/Sao_Paulo"
I dont understand why do you need to see tcpdump with src IP because that IP only come here with Netflow data, I dont have that Ip direct to my NA...
jdalrymple
Skynet Drone
Post by jdalrymple »
Was this system working prior to an upgrade, or are these entirely new sources on a new system?
If the latter, please post the config from your ASA.
martins719
It was working with old version, I didn´t change nothing in the Csco ASA Config. The routers are working but the 2 firewalls are with equal situation.
flow-export destination inside 172.20.39.201 2060
class class-default
user-statistics accounting
set connection decrement-ttl
flow-export event-type all destination 172.20.39.201
Actually, can you run this and post the output here?
 tcpdump -i eth0 port 2060
What is the ip address of the Cisco ASA that you are having problems with?
