Apply configuration does not work
maritz
Post by maritz »
Hi there,
I am using Nagios XI 2014R2.6, i made some config changes, then applied the configuration button.
Changes are not applied. I get a "401 Authorization Required, authorization failed. NagioSQL login Failed."message accord cmd.txt.
Nagios Newbee....
jdalrymple
Skynet Drone
Re: Apply configuration does not work
Post by jdalrymple »
It looks like you have tried configuring your XI server to work over https. Did you use the following document as your guide?
http://assets.nagios.com/downloads/nagi ... s%20XI.pdf
maritz
Post by maritz »
Only redirection was enabled, did not the orginal installation...
If I take this in notice and l follow the guide to install SSL,will this correct my problem?
If you are trying to enable SSL on your XI install then yes, you will need to follow that guide.
