Network Switch / Router Monitoring Wizard
davidha
Post by davidha »
Hi.
I've got a problem using the "Network Switch / Router Monitoring Wizard".
I've ran the wizard, selected SNMP v 2c, gave an IP of a router and it's community name and got an error
when tried to apply the router configuration.
Attached a printscreen.
Thank you.
nscott
Re: Network Switch / Router Monitoring Wizard
Post by nscott »
Can you post the output of Configure > Core Config Manager > Tools > Write Config Files > Check Config Files Go
Nicholas Scott
davidha
Post by davidha »
It is the same problem now with all I try to do with Nagios. I've opened a different topic and posted the output there.
Thank you.
