Hi
In NagiosXI we have a pat “/usr/local/nagios/var/spool/xidpe where many files re created, Please tell me where did the same xidpe files are created in Nagios Core , need to know it's path.
Where did xidpe files located in nagios core
wiproltdwiv
Re: Where did xidpe files located in nagios core
XI runs on top of Core, so that directory is the same in both installations. In a Core install the Nagios files may be located under a different parent directory, however the underlying structure should remain the same.
