I regularly get the following error when editing or adding actions in the actions component:
"No URL specified on line 28"
When I get this eror, the edited or added actions do not seem to be saved. SOmetimes I could solve it by recreating the action a few times and then it suddenly works. But now I'm nto able to add a new action (linking to Reactor event chain)
Is this a known issue?
EDIT: After some testing, it seems to only happen on actions linking to Reactor event chains that are near the end of the actions list. But as I have 30+ actions and am using Reactor more and more, this is becoming an issue.
Grtz
WIllem
Actions - No URL specified on line 28
Nagios XI 5.8.1
https://outsideit.net
Re: Actions - No URL specified on line 28
What is the version of the Actions component that you are currently using?
My Nagios XI Production is at the latest version of the action component, 1.5.3.
Nagios XI 5.8.1
Well, the actions component is up to date. Can you give us an example of an action that you have setup in the Actions component and the corresponding event chain in Reactor. We will need to test this in house and perhaps have developers look at it.
Ludmill,
Well, I attached two screenshots, the first one displays two Reactor event chains which I'm unable to enable, as I get the error you can see in screenshot two. I have very similar event chains which are activated and work perfect. The two event chains you see are the third and fourth last action in the list.
I hope this helps you identify the issue. Let me know if you need anything else.
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
I was able to recreate the issue. It is a bug. I already posted an internal bug report (TASK ID 5146) and spoke to our devs.
Willem,
Here's an actions component with that bug fixed.
Scott,
I can confirm the actions patch works and solves the issue. Thanks for the (very) fast solution! This thread can be closed.
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
That's great to hear, closing now.
