<snipped>
Warning: Host 'abc26esxi02' has no services associated with it!
<snipped>
Checked 6 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 25
Total Errors: 0
How can I disable "no services associated" warning message ?
After reading R1, looks like nagios command,host,service need be defined for a machine.
Following is an attempt to define a service but not actually running it.
Will following really works to my goal of ping only monitoring upon a machine ?
is just a warning telling you that there are no service checks setup for that host and can be ignored.
If all you want to check is is the host is up, you can edit your host and add the check-host-alive or check_icmp to it and that should give you the results you are looking for.
So no way to silent that warning message regarding "no services associated with a host" ?
Can we use a dummy service like following to declare service but not doing the service check ?
Not without editing the source.
nagmoto wrote:Can we use a dummy service like following to declare service but not doing the service check ?
That would work. You could also just set the check command to use check_dummy. But as active and passive checks are disabled, it will never schedule the check anyways.
