where is Nagios core documentation sources ?
nagmoto
Post by nagmoto »
Hi
I can't find doc source that render online version of Nagios 3 and 4 in github docs [R3]directory.
R1: http://nagios.sourceforge.net/docs/nagioscore/3/
R2: http://nagios.sourceforge.net/docs/nagioscore/4/
R3: https://github.com/NagiosEnterprises/na ... aster/docs
Can someone explain more about nagiocore docs status/plan ?
tj
Re: where is Nagios core documentation sources ?
Our documentation for both Core 3 and Core 4, as well as NRPE and NDOUtils is listed here:
http://library.nagios.com/library/produ ... e/manuals/
nagmoto
Post by nagmoto »
tmcdonald wrote:Our documentation for both Core 3 and Core 4, as well as NRPE and NDOUtils is listed here:
Is the source code for above documentation open-sourced ?
I am hoping to type a "make doc" command to generate doc into either PDF or html format.
tj
The ones I linked to are just plain HTML with images and CSS. I believe all of our documentation is online, judging by the Core source tree.
petergarner
Post by petergarner »
emergency! as SF is still down, does anyone know of an alternative link for core docs?
Google should have most of those pages cached:
2015-07-21 09_17_59-nagios documentation - Google Search.png (7.89 KiB) Viewed 4497 times
Links within the docs, unfortunately, will try to go to the SF pages still, so they'll need to be viewed from cache as well.
Post by Box293 »
SF seems to be back up now.
Also, we have moved Core documentation so it will be able to be accessed if this were to happen in the future
Nagios Core Documentation
