CentOS - New Installation Error
timlee
Post by timlee »
Hi there,
Got a problem when doing a new installation using
./fullinstall
on CentOS, which previously was working well. Attached the install.log
Setting up Install Process
Loading mirror speeds from cached hostfile
Error: Cannot find a valid baseurl for repo: base
Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=6&arch=x86_64&repo=os&infra=stock error was
14: PYCURL ERROR 6 - "Couldn't resolve host 'mirrorlist.centos.org'"
RESULT=1
jdalrymple
Skynet Drone
Re: CentOS - New Installation Error
Post by jdalrymple »
This is a DNS issue when trying to add some base packages that are necessary. I've seen this multiple times in the past few weeks, the problem is likely transient.
Unfortunately it's out of our control, but I suspect if you tried again today the problem will have solved itself.
Just for curiosities sake, are you using public DNS or do you host your own and use forwarders? Where are your forward requests going?
timlee
Post by timlee »
jdalrymple wrote:This is a DNS issue when trying to add some base packages that are necessary. I've seen this multiple times in the past few weeks, the problem is likely transient.
I sincerely apologize for my mistake... I didn't put in the DNS in /etc/sysconfig/network-scripts/ifcfg-eth0
It's working now :oops:
jdalrymple
Skynet Drone
An easy oversight - glad you got it sorted!
