Radius server check
amitkhare
Radius server check
Post by amitkhare »
Hello All,
I have configured a radius server running Radiator on our Nagios XI instance, but keep getting the following error. I tried to upgrade the radiusclient.ng but still no luck,
(No output on stdout) stderr: /bin/sh: -c: line 0: unexpected EOF while looking for matching `"'
/bin/sh: -c: line 1: syntax error: unexpected end of file
Has anyone else experienced the same problem. Thanks,
Amit
jdalrymple
Skynet Drone
Re: Radius server check
Post by jdalrymple »
Hi Amit,
It's not really clear at all to me what you're trying to do. Are you wanting to monitor your radiator server or authenticate Nagios users with it?
