NRPE and templates
bbailey6
NRPE and templates
Post by bbailey6 »
I am trying to wrap my head around nrpe. I currently have it working but I feel like I am doing something wrong. I cant get any data back from hosts I am trying to monitor without adding flags to my nrpe.cfg.
What I have right now, which works is:
command[check_swap]=/usr/local/nagios/libexec/check_swap -w $ARG1$ -c $ARG2$
is it possible to just have a generic nrpe.cfg on all the clients I want to monitor? i.e.:
command[check_swap]=/usr/local/nagios/libexec/check_swap $ARG1$ $ARG2$
and then just pass the arguments through the defined service on my nagios? What the heck am I doing wrong? Do I need to create a custom template for each plugin?
Re: NRPE and templates
It is entirely possible to use arbitrary args, but be warned this can be a security risk:
http://www.thegeekstuff.com/2010/12/ena ... arguments/
bbailey6
Post by bbailey6 »
Hi Donald,
I've set the don't blame nrpe flag to 1 and also compiled with the --enable-command-args option.
Actually, since its been a few weeks of playing with it, is there a way to see if I did in fact run ./configure --enable-command-args
thanks
jdalrymple
Skynet Drone
Post by jdalrymple »
[jdalrymple@localhost nrpe-2.15]$ grep "enable-command-args" config.status
  with options \"'--enable-command-args'\"
  echo "running /bin/sh ./configure " '--enable-command-args' $ac_configure_extra_args " --no-create --no-recursion" >&6
  exec /bin/sh ./configure '--enable-command-args' $ac_configure_extra_args --no-create --no-recursion
If there is no output, you did not compile with the --enable-command-args flag
bbailey6
Post by bbailey6 »
hi,
looks like its there
nrpe-2.15]# grep "enable-command-args" config.status
is it not possible to not add flags to my nrpe.cfg? id like to write all the custom services from the nagios side and all necessary flags there
I didn't install nrpe on the nagios side, only the client side. Do you have to install it on the nagios side with --enable-command-args?
jdalrymple
Skynet Drone
It's very possible - have you tried?
[jdalrymple@localhost libexec]$ ./check_nrpe -H localhost -c check_disk -a '-w 20 -c 10 -p /'
DISK OK - free space: / 13338 MB (79% inode=92%);| /=3471MB;17689;17699;0;17709
[jdalrymple@localhost libexec]$ ./check_nrpe -H localhost -c check_disk -a '-w 20 -c 10 -p /boot'
DISK OK - free space: /boot 427 MB (93% inode=99%);| /boot=31MB;464;474;0;484
Post by Box293 »
I've struggled before with what you are trying to do.
This is how your generic command needs to be defined:
Here's how you execute it from the nagios host:
./check_nrpe -H remoteserver -c check_swap -a '-w 50 -c 20'
The key here is enclosing the arguments in single quotes. This means it is sent as one argument.
bbailey6
Post by bbailey6 »
Box293:
Thank you very much. That was driving me mad!
jdalrymple
Skynet Drone
Sounds like this is resolved for you bbailey6?
Can we lock the thread?
bbailey6
Post by bbailey6 »
Sure. And thanks!
