Hi All,
Just wondering if anyone has ever had the need to remove the Nagios Process icon from the status map view. I like the pre laid out ballon layout as it changes depending on the service status.
Any idea on how I could do this?
Remove Nagios Process from Status Map
jdalrymple
- Skynet Drone
Re: Remove Nagios Process from Status Map
http://nagios.sourceforge.net/docs/3_0/ ... tusmap_cgi
I've made some custom modifications to the statusmap.c file before:
http://sourceforge.net/p/nagios/nagiosc ... tatusmap.c
To achieve some customizations I wanted. In lieu of doing that I'd recommend using a more advanced visualization tool such as nagvis which allows you to do exactly what you want.
