mrtg graphs
Pikmin
mrtg graphs
Post by Pikmin »
Hi there
I keep getting these in the mrtg.log file, any chance someone can help me resolve them?
Use of uninitialized value in concatenation (.) or string at /usr/bin/mrtg line 1326.
Use of uninitialized value in concatenation (.) or string at /usr/bin/mrtg line 1335.
Also I'm getting mails about this:
2-03-2015 15:00:05, Rateup ERROR: /usr/bin/rateup found that 192.168.100.2_10108's log file time of 1426132803 was great
er than now (1426132802)
ERROR: Let's not do the time warp, again. Logfile unchanged.
12-03-2015 15:00:05, Rateup ERROR: /usr/bin/rateup found that 192.168.100.2_10109's log file time of 1426132803 was great
12-03-2015 15:00:05, Rateup ERROR: /usr/bin/rateup found that 192.168.100.2_10110's log file time of 1426132803 was great
I did change the time on the server to use ntp from windows domain, from there I have deleted and regenerated all the log files with cfgmaker and still keep getting those errors
Re: mrtg graphs
Post by Box293 »
Are you getting any messages about MRTG in /var/spool/mail/root ?
Pikmin
Re: mrtg graphs
Post by Pikmin »
Hi yes,
This morning I checked and there are 362 messages since yesterday
jolson
Attack Rabbit
Re: mrtg graphs
Post by jolson »
Any chance SELinux is running on this box?
sestatus
If so, try disabling it temporarily and see if that helps:
setenforce 0
Twits Blog
Pikmin
Re: mrtg graphs
Post by Pikmin »
Hi there,
SELinux is disabled
Re: mrtg graphs
Post by Box293 »
Pikmin wrote:Hi yes,
Can you please post one of these messages in it's entirety (from /var/spool/mail/root).
With that information I should be able to give you a fix.
Pikmin
Re: mrtg graphs
Post by Pikmin »
Here you go :)
From [email protected]  Thu Mar 12 16:20:12 2015
Return-Path: <[email protected]>
X-Original-To: root
Delivered-To: [email protected]
Received: by localhost.localdomain (Postfix, from userid 0)
        id 44CC2388D30; Thu, 12 Mar 2015 16:20:08 +1100 (EST)
Subject: Cron <root@localhost> /usr/bin/env /usr/bin/mrtg /etc/mrtg/mrtg.cfg --logging /var/log/mrtg.log
Content-Type: text/plain; charset=UTF-8
Auto-Submitted: auto-generated
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=root>
X-Cron-Env: <USER=root>
Message-Id: <[email protected]>
Date: Thu, 12 Mar 2015 16:20:04 +1100 (EST)
Status: O
12-03-2015 16:20:04, Rateup WARNING: /usr/bin/rateup Can't remove 192.168.100.3_100.old updating log file
12-03-2015 16:20:04, Rateup WARNING: /usr/bin/rateup Can't remove 192.168.100.3_10101.old updating log file
12-03-2015 16:20:05, Rateup WARNING: /usr/bin/rateup could not read the primary log file for 192.168.100.1_28
12-03-2015 16:20:05, Rateup ERROR: /usr/bin/rateup found 192.168.100.1_28's log file was corrupt
          or not in sorted order:
time: 1421121600.12-03-2015 16:20:05, Rateup WARNING: /usr/bin/rateup The backup log file for 192.168.100.1_28 was invalid as well
From [email protected]  Thu Mar 12 16:20:14 2015
X-Original-To: root
        id EABDD388C9E; Thu, 12 Mar 2015 16:20:08 +1100 (EST)
Subject: Cron <root@localhost> LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok
Status: O
12-03-2015 16:20:04, Rateup WARNING: /usr/bin/rateup could not read the primary log file for 192.168.100.3_100
12-03-2015 16:20:04, Rateup WARNING: /usr/bin/rateup Can't rename 192.168.100.3_100.log to 192.168.100.3_100.old updating log file
12-03-2015 16:20:04, Rateup WARNING: /usr/bin/rateup could not read the primary log file for 192.168.100.3_10101
12-03-2015 16:20:04, Rateup WARNING: /usr/bin/rateup Can't rename 192.168.100.3_10101.log to 192.168.100.3_10101.old updating log file
Thursday, 12 March 2015 at 16:20: ERROR: Skipping webupdates because rateup did not return anything sensible
Thursday, 12 March 2015 at 16:20: WARNING: rateup died from Signal 0
 with Exit Value 1 when doing router '192.168.100.1_28'
 Signal was 0, Returncode was 1
12-03-2015 16:20:06, Rateup ERROR: /usr/bin/rateup found that 192.168.100.1_10201's log file time of 1426137603 was greater than now (1
426137602)
12-03-2015 16:20:06, Rateup ERROR: /usr/bin/rateup found that 192.168.100.1_10202's log file time of 1426137603 was greater than now (1
426137602)
12-03-2015 16:20:06, Rateup ERROR: /usr/bin/rateup found that 192.168.100.1_10610's log file time of 1426137603 was greater than now (1
426137602)
12-03-2015 16:20:06, Rateup ERROR: /usr/bin/rateup found that 192.168.100.1_10611's log file time of 1426137603 was greater than now (1
426137602)
Re: mrtg graphs
Post by Box293 »
In your config file, are these ports valid ports and do you want to collect data on them?
192.168.100.1_28
192.168.100.1_10201
192.168.100.1_10202
192.168.100.1_10610
192.168.100.1_10611
If they are not, simply comment out the lines for each port (it can be 30+ lines).
Pikmin
Re: mrtg graphs
Post by Pikmin »
192.168.100.1_28 Vl28 (Vlan28 Virtual Interface)
192.168.100.1_10201 Te1/1/1
192.168.100.1_10202 Te1/1/2
192.168.100.1_10610 Gi2/0/10
192.168.100.1_10611 Gi2/0/10
I would like to monitor vlan28, even though there's very little traffic on it
The others are not connected so I could comment them out
Thank you
Re: mrtg graphs
Post by Box293 »
First just try commenting out those ports you don't need and observe.
If number 28 persists to be a problem, I would try deleting the file for 192.168.100.1_28 and see if that fixes the problem.
