restore configuration snapshot
venkitesh
Post by venkitesh »
hi
any one knows how to restore a configuration snapshot.
i am not asking for this /usr/local/nagiosxi/scripts/restore_xi.sh <backupfile.tar.gz>
i have downloaded a configuration snapshot of 45KB . any idea how to restore that
its not showing in the list of snapshots in gui, i think it will show only top 10
ssax
Dreams In Code
Re: restore configuration snapshot
Post by ssax »
You can place the file in /usr/local/nagiosxi/nom/checkpoints/nagioscore/archives
If that directory doesn't exist you can click the archive button on one of your snapshots (far right button under actions) in manage snapshots.
make sure to run the command below after placing the file in there:
chown nagios.users NAMEOFFILE.tar.gz
venkitesh
Post by venkitesh »
hi ssax,
when i try to restore its showing snapshot doesnt exist.
jolson
Attack Rabbit
Post by jolson »
Please run the following command to check for proper permissions:
ll /usr/local/nagiosxi/nom/checkpoints/nagioscore/archives/
Set permissions properly if they are incorrect:
chmod -R 644 /usr/local/nagiosxi/nom/checkpoints/nagioscore/archives/*
Please let us know if the above works for you. Thank you!
Twits Blog
