passive service history retention
WillemDH
Post by WillemDH »
i'm 100% sure last week we had several passive events in one of my passive services which catches realtime Windows events. Yesterday we rebooted this server in the hope the issue causing the passive events to be solved. So today I wanted to check the service history of this passive service. But it seems the history is completely empty. What could have caused this?
See screenshots for the config of the passive service.
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
ssax
Dreams In Code
Re: passive service history retention
Post by ssax »
Are they missing from all your passive services or just this one?
WillemDH
Post by WillemDH »
Just this one it seems.
Nagios XI 5.8.1
jolson
Attack Rabbit
Post by jolson »
Please run the following on your Nagios box:
mysql -pnagiosxi nagios
select host_object_id,alias,display_name from nagios_hosts;
select object_id,output,statehistory_id,last_state,last_hard_state from nagios_statehistory where object_id = <hostobjectID>;
Please replace <hostobjectID> with the hosts object ID that is in question. Once you pull up that table, look for any states related to the passive check. Do any exist?
Twits Blog
WillemDH
Post by WillemDH »
Getting access denied. Also when I try with root pw....
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
Nagios XI 5.8.1
jolson
Attack Rabbit
Post by jolson »
Can you please perform the following procedure to reset your root database password:
Before doing anything, stop mysql:
service mysqld stop
Start MySQL in safe mode:
 mysqld_safe --skip-grant-tables
In a different terminal, log into mysql as root, using the mysql DB:
mysql mysql
In the MySQL Shell, reset the root DB password:
update user set Password=PASSWORD('new-password') where user='root';
flush privileges;
exit;
The FLUSH statement tells the server to reload the grant tables into memory so that it notices the password change.
Stop the server, then restart it normally:
service mysqld stop
service mysqld start
http://dev.mysql.com/doc/refman/5.0/en/ ... sions.html
This does not have any impact on the functionality of your system, I made sure to test the results in a lab quickly. :D
EDIT:
There is one password you will need to change - it's located in the following file:
vi /root/scripts/automysqlbackup
You will need to change the 'default' password to your newly created root password.
Twits Blog
WillemDH
Post by WillemDH »
Jolson,
Just one question before I start following your procedure. Why would I suddenly need to reset this password? I don't get it. My backup is working correctly etc. I don't understand.
Grtz
Willem
Nagios XI 5.8.1
You don't have to do this. I believe what jolson was saying is that if you changed the root mysql password, you would also need to change it in the "/root/scripts/automysqlbackup" script. If you know the "new" root password, use it to obtain the info.
mysql -p<you new password> nagios
If you don't know your new password, you can try:
mysql -u ndoutils -pn@gweb nagios
\q
WillemDH
Post by WillemDH »
Ah,
Ty Ludmill, my problem was that I copy pasted Jolson's command not knowing that the password had to be right after the p. he should have said
mysql -p<mysqlpassword> nagios
or sth similar. :)
Ok, the output of the third command:
mysql> select object_id,output,statehistory_id,last_state,last_hard_state from nagios_statehistory where object_id = 6989;
| object_id | output        | statehistory_id | last_state | last_hard_state |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          476522 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          476528 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          476538 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 2.167ms, lost 0%                                     |          476564 |          1 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          483689 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 0.711ms, lost 0%                                     |          483700 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: rta nan, lost 100%                                 |          506205 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 0.185ms, lost 0%                                     |          506206 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          567717 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          567736 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          567749 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 0.442ms, lost 0%                                     |          570042 |          1 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: rta nan, lost 100%                                 |          589962 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          589964 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |          589969 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 2.116ms, lost 0%                                     |          589972 |          1 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: rta nan, lost 100%                                 |          735457 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 0.272ms, lost 0%                                     |          735458 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: rta nan, lost 100%                                 |          758845 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 0.385ms, lost 0%                                     |          758846 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: rta nan, lost 100%                                 |          913363 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 0.348ms, lost 0%                                     |          913365 |          0 |              -1 |
|      6989 | CRITICAL - 10.10.10.101: Host unreachable @ 10.54.24.99. rta nan, lost 100% |         1051750 |          0 |              -1 |
|      6989 | OK - 10.10.10.101: rta 0.344ms, lost 0%                                     |         1051752 |          0 |              -1 |
24 rows in set (0.00 sec)
It seems this command only shows the state history of the host? The history I was missing was that of one service of this host, named EVT_Application.
Grtz
Willem
Nagios XI 5.8.1
WillemDH
Post by WillemDH »
Ok.. My I discovered this server is a 2003 and gpo events are stored in System eventlog there it seems. So I was looking in the wrong service history. Sorry! :oops:
But while we are talking about passive services, I've got another question. The json query to get recentalerts of the last 24 hours I'm doing on another server is giving me more results then the service history in Nagios. I vaguely remember some passive service setting to not overwrite the service if the state was already non healthy. You can see the settings of my passive service in one of my earlier posts.
if the json query to get recent alerts is showing more information then the service history in Nagios, this is kind of confusing.
This is the json query:
query=alertlist&objecttypes=host+service&statetypes=hard&servicestates=warning+critical+unknown&hostname=<servername>&starttime=$Start&endtime=$End")
The results you can see in the attachments.
So what setting was it again to overwrite passive services? And is there a way to edit the json query so it shows the same results as Nagios XI service history?
Grtz
Nagios XI 5.8.1
