No Hosts, No Services, notification disabled
botswanamtc
Post by botswanamtc »
Morning,
I have a problem with NagiosXI, I schedulled a downtime for the weekend as we had a power maintenance over the weekend. Now I have the following problems.....all hosts (1000+) have notifications diabled. I cannot access services for a single host by clicking on service detail for any host.
the system shows no hosts and no services under System Profile.
Kindly help.
Regards,
Re: No Hosts, No Services, notification disabled
Check the mysqld.log for errors/crashed tables:
tail -50 /var/log/mysqld.log
Run the database repair script if you need to:
./repair_databases.sh
Stop/start services:
service nagios stop
service ndo2db stop
service ndo2db start
service nagios start
service mysqld restart
Check the number of hosts/services from the CLI:
echo 'select count(*) from nagios.nagios_hosts;' | mysql -t -pnagiosxi
echo 'select count(*) from nagios.nagios_services;' | mysql -t -pnagiosxi
Are you getting the correct numbers?
