Updating OS/Kernel on a Nagios Server
and1100
Post by and1100 »
I am planning on updating our Nagios server OS and kernel from CentOS 6.4, 2.6.32-358.2.1.el6.x86_64 to CentOS 6.6. Is there anything disruptive that I need to be concerned with when I perform the yum update, other than the reboot? Unfortunately, I have not done a kernel update on a Nagios server before and was worried I would break our Nagios after updating the kernel.
Thank you.
ssax
Dreams In Code
Re: Updating OS/Kernel on a Nagios Server
Post by ssax »
You should be fine but make sure that you do have a full backup/snapshot just in case.
and1100
Post by and1100 »
Will do. Thank you, ssax.
ssax
Dreams In Code
Post by ssax »
No problem, let us know if you run into any issues.
