IIS and https current connection
emi65
Post by emi65 »
Hi
I need to monitor the number of https active connection on IIS site .
Do you know the OID of https connection ?
Many thanks for your help
Emilio
jdalrymple
Skynet Drone
Re: IIS and https current connection
Post by jdalrymple »
Quick google leads me to this OID for IIS6: 1.3.6.1.4.1.311.1.7.3.1.13.0
This may not be true for newer versions, can you test and let us know?
--EDIT--
Here is a sample checkcommand from our exchange:
http://exchange.nagios.org/directory/Pl ... ks/details
command[snmp_http_connections]=/usr/local/nagios/libexec/check_snmp -H $HOSTADDRESS$ -C $ARG1$ -o .1.3.6.1.4.1.311.1.7.3.1.13.0 -u 'HTTP Connections' -d:
emi65
Post by emi65 »
This OID work but ...... Does the number of HTTP or HTTPS connections ?
tks
Emilio
jdalrymple
Skynet Drone
I see, you're looking for specifically a number of connections open using https, not just IIS connections. It seems from what I can read this is either specific to http, or perhaps a global counter for both types of connections. You may need to use a custom plugin counting the number of established connections on port 443, using OS tools instead of asking IIS.
Do you have a remote monitoring agent setup on this computer? If not would it be possible to install one?
There is a very useful Powershell script written by a Nagios contributor:
http://exchange.nagios.org/directory/Pl ... ns/details
This when run remotely can achieve what you want.
