Can't add sources with dash (-) in the name after 2R1.0
- snapon_admin
Found another bug: after the upgrade we can no longer include dashes in source names. All of our existing sources that have dashes in the name (i.e. Site-MPLS) work fine, but we get an invalid name warning when trying to add new sources with a dash in the name.
Re: Can't add sources with dash (-) in the name after 2R1.0
We had an internal bug report filed about this (task ID=5050). The dashes were causing issues, so we no longer allow them, sorry.
- snapon_admin
Hmmm, well crap. Anything wrong with keeping our existing sources (that have dashes) the way they are? All of them are working fine and I'd say about 90% of our sources have dashes.
I believe the old ("existing sources") should be fine but you won't be able to add new sources/source groups with a dash in the name. If you run into some issues, let us know though asap.
- snapon_admin
Alrighty, will do. Thanks, lock her up.
