backup
pccwglobalit
backup
Post by pccwglobalit »
i have 4 nodes clusters and i mounted them to SAME nfs. also setup repository.
but now i cannot see it is backup. how can i check the backup schedule and see if they are running?
pccwglobalit
Re: backup
i can see the backup is finished in audit report.
however, where i can find the backup?
jolson
Attack Rabbit
Re: backup
Post by jolson »
My example backup repository is "/bkk/". Please review the attached picture and ensure that the areas I have circled are appearing properly in your WebGUI.
If the repository is setup properly and selected, be sure that you have pressed 'Apply Configuration'. Once that has been done, you can force the first backup from the Command Subsystem (Run the backup_maintenance job).
Twits Blog
pccwglobalit
Re: backup
please see my screen from attachment.
i did apply configuration again.
jolson
Attack Rabbit
Re: backup
Post by jolson »
I do not see your attachment - could you please attach it once more?
Twits Blog
pccwglobalit
Re: backup
i cannot upload jpeg. it said "Sorry, the board attachment quota has been reached."
jolson
Attack Rabbit
Re: backup
Post by jolson »
We have bumped the attachment limit - could you please post your attachment now?
Twits Blog
pccwglobalit
Re: backup
pccwglobalit
Re: backup
thanks
jolson
Attack Rabbit
Re: backup
Post by jolson »
Could you please get a screenshot of your 'Command Subsystem' page to us?
I would like you to log into the CLI on each of your nodes and run the following:
tail -f /usr/local/nagioslogserver/var/jobs.log
We should try and force a backup to run by clicking 'Edit' next to 'backup_maintenance', and selecting the time as 'Now'. This should force a backup to begin on your nodes.
Twits Blog
