Hi everyone
another problem with Nagios XI 2014R2.4 from us:
When a user changes the ip-address of a host via Configure -> "Re-configure this host" the host loses its relationships to all of its contactgroups.
Can you reproduce this?
Best wishes
b2m
Hostgroups disappear when changing ip-address
Re: Hostgroups disappear when changing ip-address
Are you changing the hostname or just the address?
EDIT: If you are changing the hostname, please use the renaming tool to do so.
just the ip-address.
Does it still exhibit this behavior when you make the edit straight from the CCM?
No, via CCM it works fine. The relationships to the notificationgroups are still there after applying configuration.tmcdonald wrote:Does it still exhibit this behavior when you make the edit straight from the CCM?
Can you show us the config before and after you change the IP address via "Configure->Re-configure this host"? It is a very strange issue. I don't remember anyone else reporting this before. Is upgrading your Nagios XI to the latest (2.6) an option for you?
I found out this only applies when a non admin user changes the address.
We'll upgrade to newest version as soon as possible.
After:
# Host configuration file
# Created by: Nagios Core Config Manager 2.3.1
# Date: 2015-03-19 16:34:09
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define host {
host_name niagara_01_z028
use xiwizard_genericnetdevice_host
address 10.182.82.221
hostgroups messsysteme,StO_N
max_check_attempts 5
check_interval 15
retry_interval 1
contact_groups Team BNG,Team Messmittel
notification_interval 0
first_notification_delay 0
notifications_enabled 1
_xiwizard genericnetdevice
register 1
# END OF FILE
###############################################################################Code: Select all
# Date: 2015-03-19 16:36:39
define host {
address 10.182.82.222
check_interval 15
retry_interval 1
register 1
# END OF FILE
###############################################################################Re: Hostgroups disappear when changing ip-address
I tested this scenario on the latest release of XI and I was not able to recreate the issue.I found out this only applies when a non admin user changes the address.
Let us know if the issue persists after the upgrade.We'll upgrade to newest version as soon as possible.
I've upgraded to 2014R2.6. The issue is still there.
Best wishes
mb2m
Best wishes
mb2m
We will have to probably move this to our email ticketing system. Can you send us your latest profile to [email protected]? Type "Hostgroups disappear when changing ip-address" in the email's subject field.
Admin->System Profile->Download Profile
