Nagios Core Config Manager not showing up ver.2
stecino
Post by stecino »
I know that that there was already a topic opened for this,
and one of the suggested solutions is here http://support.nagios.com/forum/viewtop ... 9061#p9061
But I am not going though proxy. I have looked at all the underlying http calls using fire bug, I am not seeing any issues. Anything else could be wrong?
Re: Nagios Core Config Manager not showing up ver.2
Post by Box293 »
Can you please post a screenshot of the problem.
stecino
Post by stecino »
Box293 wrote:Can you please post a screenshot of the problem.
Please see attached
Post by Box293 »
I'm not seeing what the problem is sorry.
stecino
Post by stecino »
Box293 wrote:I'm not seeing what the problem is sorry.
There supposed to be login screen there?
Post by Box293 »
Right I see what you are saying. This is a feature added in 2014R1.4:
Added automated login when accessed from inside of Nagios XI if the user is an admin -JO
If you want the old behaviour:
Admin > System Config
Check the box Separate CCM Login
Click Update Settings button
