Nagios® Core™ Version 4.0.8
I have installed Nagios® Core™ Version 4.0.8 on Ubuntu 14.04. When i installed Nagios on this machine, i faced problem with adding linux client.
my linux client version same as server Nagios.
on client side /etc/nagios/nrpe.cfg output
allowed_hosts=192.168.169.121,127.0.0.1
command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
command[check_load]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$
command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
also
root@dosya-paylasim:/usr/lib/nagios/plugins# lsof -i:5666
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
nrpe 8659 nagios 4u IPv4 154828 0t0 TCP *:nrpe (LISTEN)
nrpe 8659 nagios 5u IPv6 154829 0t0 TCP *:nrpe (LISTEN)
at server side my command.cfg
# 'check_local_disk' command definition
command_name check_local_disk
command_line $USER1$/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
# 'check_local_load' command definition
command_name check_local_load
command_line $USER1$/check_load -w $ARG1$ -c $ARG2$
# 'check_local_procs' command definition
command_name check_local_procs
command_line $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
# 'check_local_users' command definition
command_name check_local_users
command_line $USER1$/check_users -w $ARG1$ -c $ARG2$
# 'check_local_swap' command definition
command_name check_local_swap
command_line $USER1$/check_swap -w $ARG1$ -c $ARG2$
# 'check_local_mrtgtraf' command definition
command_name check_local_mrtgtraf
command_line $USER1$/check_mrtgtraf -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
my remote machine cfg file is ubuntu.cfg and services identified as,
# HOST DEFINITION
# Define a host for the local machine
use linux-server ; Name of host template to use
; This host definition will inherit all variables that are defined
; in (or inherited by) the linux-server host template definition.
host_name domates.karel.com.tr
alias dosya_paylasim1
address 192.168.169.120
# SERVICE DEFINITIONS
# Define a service to "ping" the local machine
use generic-service ; Name of service template to use
service_description PING
check_command check_ping!100.0,20%!500.0,60%
# Define a service to check the disk space of the root partition
# on the local machine. Warning if < 20% free, critical if
# < 10% free space on partition.
service_description Root Partition
check_command check_local_disk!20%!10%!/
# Define a service to check the number of currently logged in
# users on the local machine. Warning if > 20 users, critical
# if > 50 users.
service_description Current Users
check_command check_local_users!20!50
# Define a service to check the number of currently running procs
# on the local machine. Warning if > 250 processes, critical if
# > 400 users.
service_description Total Processes
check_command check_local_procs!250!400!RSZDT
# Define a service to check the load on the local machine.
service_description Current Load
check_command check_local_load!5.0,4.0,3.0!10.0,6.0,4.0
# Define a service to check the swap usage the local machine.
# Critical if less than 10% of swap is free, warning if less than 20% is free
service_description Swap Usage
check_command check_local_swap!20!10
# Define a service to check SSH on the local machine.
# Disable notifications for this service by default, as not all users may have SSH enabled.
service_description SSH
check_command check_ssh
notifications_enabled 0
# Define a service to check HTTP on the local machine.
# Disable notifications for this service by default, as not all users may have HTTP enabled.
service_description HTTP
check_command check_http
bu i have trouble at some of the services which are attached to mail
i checked my root partition shows wrong.i assume that others would be too.
also
# HOST DEFINITION
# if > 50 users.
# > 400 users.
Re: Nagios® Core™ Version 4.0.8
Open the /usr/local/nagios/etc/resource.cfg file in your preferred text editor.
Edit the $USER1$ macro (typically the second line of the file) to be as follows:
Save and close the file, then restart Nagios with the following command:
Let us know if that works for you.
$USER1$=LC_ALL=C /usr/local/nagios/libexecCode: Select all
service nagios restartRe: Nagios® Core™ Version 4.0.8
Unfortunately it doesn't work. because it is defined formerly.
actually the issue is, client defination about the root partition same as the local nagios server.
what i am doing wrong.
}So it is not performing a nrpe check on the other server.
You need to define an NRPE command on the nagios server like so
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
check_command check_nrpe!check_disk!-a ' 20% 10% /'
}Re: Nagios® Core™ Version 4.0.8
First of all thanks for your information scottwilkerson,
my client ip is 192.168.169.120
i try nrpe_check at client side but i got
root@dosya-paylasim:/etc/nagios# /usr/lib/nagios/plugins/check_nrpe -H localhost
CHECK_NRPE: Error - Could not complete SSL handshake.
after that i installed xinetd, but same error it does
root@dosya-paylasim:/usr/local/nagios/libexec# /usr/lib/nagios/plugins/check_nrpe -H 192.168.169.120
@ nagios server (192.168.169.121)
root@dosya:/usr/local/nagios/etc/servers# /usr/lib/nagios/plugins/check_nrpe -H 192.168.169.120
NRPE v2.15
You have new mail in /var/mail/root
my nagios server ip 192.168.169.121
my nrpe.cfg file
root@dosya-paylasim:/etc/nagios# egrep -v '^#|^$' nrpe.cfg
log_facility=daemon
pid_file=/var/run/nagios/nrpe.pid
server_port=5666
nrpe_user=nagios
nrpe_group=nagios
dont_blame_nrpe=0
allow_bash_command_substitution=0
debug=0
command_timeout=60
connection_timeout=300
command[check_all_disk]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10%
command[check_all_disks]=/usr/lib/nagios/plugins/check_disk -w 20 -c 10
include=/etc/nagios/nrpe_local.cfg
also my
root@dosya-paylasim:/usr/local/nagios/libexec# ls -ltr
total 0
lrwxrwxrwx 1 root root 34 Mar 18 23:13 check_nrpe -> /usr/lib/nagios/plugins/check_nrpe
lrwxrwxrwx 1 root root 35 Mar 19 09:50 check_users -> /usr/lib/nagios/plugins/check_users
lrwxrwxrwx 1 root root 34 Mar 19 09:50 check_load -> /usr/lib/nagios/plugins/check_load
lrwxrwxrwx 1 root root 34 Mar 19 09:50 check_disk -> /usr/lib/nagios/plugins/check_disk
lrwxrwxrwx 1 root root 35 Mar 19 09:51 check_procs -> /usr/lib/nagios/plugins/check_procs
root@dosya-paylasim:/usr/lib/nagios/plugins# ls -ltr
total 2256
-rwxr-xr-x 1 root root 22992 Jan 13 2014 check_nrpe
-rwxr-xr-x 1 root root 2917 Mar 12 2014 utils.sh
-rw-r--r-- 1 root root 1936 Mar 12 2014 utils.pm
-rwxr-xr-x 1 root root 2930 Mar 12 2014 check_wave
-rwxr-xr-x 1 root root 1453 Mar 12 2014 check_sensors
-rwxr-xr-x 1 root root 9575 Mar 12 2014 check_rpc
-rwxr-xr-x 1 root root 8781 Mar 12 2014 check_oracle
-rwxr-xr-x 1 root root 20278 Mar 12 2014 check_mailq
-rwxr-xr-x 1 root root 6023 Mar 12 2014 check_log
-rwxr-xr-x 1 root root 6881 Mar 12 2014 check_ircd
-rwxr-xr-x 1 root root 12589 Mar 12 2014 check_ifstatus
-rwxr-xr-x 1 root root 15128 Mar 12 2014 check_ifoperstatus
-rwxr-xr-x 1 root root 6309 Mar 12 2014 check_flexlm
-rwxr-xr-x 1 root root 3047 Mar 12 2014 check_file_age
-rwxr-xr-x 1 root root 9283 Mar 12 2014 check_disk_smb
-rwxr-xr-x 1 root root 2236 Mar 12 2014 check_breeze
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_udp -> check_tcp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_ssmtp -> check_tcp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_spop -> check_tcp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_simap -> check_tcp
lrwxrwxrwx 1 root root 10 Mar 12 2014 check_rta_multi -> check_icmp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_pop -> check_tcp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_nntps -> check_tcp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_nntp -> check_tcp
lrwxrwxrwx 1 root root 10 Mar 12 2014 check_ldaps -> check_ldap
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_jabber -> check_tcp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_imap -> check_tcp
lrwxrwxrwx 1 root root 10 Mar 12 2014 check_host -> check_icmp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_ftp -> check_tcp
lrwxrwxrwx 1 root root 9 Mar 12 2014 check_clamd -> check_tcp
-rwxr-xr-x 1 root root 39048 Mar 12 2014 urlize
-rwxr-xr-x 1 root root 43336 Mar 12 2014 negate
-rwxr-xr-x 1 root root 39080 Mar 12 2014 check_users
-rwxr-xr-x 1 root root 51576 Mar 12 2014 check_ups
-rwxr-xr-x 1 root root 47480 Mar 12 2014 check_time
-rwxr-xr-x 1 root root 60248 Mar 12 2014 check_tcp
-rwxr-xr-x 1 root root 43240 Mar 12 2014 check_swap
-rwxr-xr-x 1 root root 43384 Mar 12 2014 check_ssh
-rwxr-xr-x 1 root root 72936 Mar 12 2014 check_snmp
-rwxr-xr-x 1 root root 64216 Mar 12 2014 check_smtp
-rwxr-xr-x 1 root root 47512 Mar 12 2014 check_real
-rwxr-xr-x 1 root root 55992 Mar 12 2014 check_procs
-rwxr-xr-x 1 root root 55768 Mar 12 2014 check_ping
-rwxr-xr-x 1 root root 51896 Mar 12 2014 check_pgsql
-rwxr-xr-x 1 root root 47416 Mar 12 2014 check_overcr
-rwxr-xr-x 1 root root 67928 Mar 12 2014 check_nwstat
-rwxr-xr-x 1 root root 51632 Mar 12 2014 check_ntp_time
-rwxr-xr-x 1 root root 55960 Mar 12 2014 check_ntp_peer
-rwxr-xr-x 1 root root 55736 Mar 12 2014 check_ntp
-rwxr-xr-x 1 root root 47376 Mar 12 2014 check_nagios
-rwxr-xr-x 1 root root 47552 Mar 12 2014 check_mysql_query
-rwxr-xr-x 1 root root 51968 Mar 12 2014 check_mysql
-rwxr-xr-x 1 root root 43280 Mar 12 2014 check_mrtgtraf
-rwxr-xr-x 1 root root 43400 Mar 12 2014 check_mrtg
-rwxr-xr-x 1 root root 43208 Mar 12 2014 check_load
-rwxr-xr-x 1 root root 47784 Mar 12 2014 check_ldap
-rwxr-xr-x 1 root root 43472 Mar 12 2014 check_ide_smart
-rwxr-xr-x 1 root root 59440 Mar 12 2014 check_icmp
-rwxr-xr-x 1 root root 93528 Mar 12 2014 check_http
-rwxr-xr-x 1 root root 51392 Mar 12 2014 check_hpjd
-rwxr-xr-x 1 root root 34808 Mar 12 2014 check_dummy
-rwxr-xr-x 1 root root 51608 Mar 12 2014 check_dns
-rwxr-xr-x 1 root root 60568 Mar 12 2014 check_disk
-rwxr-xr-x 1 root root 51728 Mar 12 2014 check_dig
-rwxr-xr-x 1 root root 55672 Mar 12 2014 check_dhcp
-rwxr-xr-x 1 root root 59928 Mar 12 2014 check_dbi
-rwxr-xr-x 1 root root 39248 Mar 12 2014 check_cluster
-rwxr-xr-x 1 root root 56120 Mar 12 2014 check_by_ssh
-rwxr-xr-x 1 root root 51624 Mar 12 2014 check_apt
NRPE v2.15
my nrpe.cfg file
log_facility=daemon
server_port=5666
nrpe_user=nagios
nrpe_group=nagios
dont_blame_nrpe=0
debug=0
command_timeout=60
also my
total 0
total 2256
jdalrymple
- Skynet Drone
NRPE is run from the Nagios server side, you would rarely have a need to run `check_nrpe -H localhost`
nrpe.cfg defines what is done at the client side when the check_nrpe command runs at the server side reaching out to the client side. The roles get flip flopped as the nrpe server is running on the client and the nrpe client is on the server.
Adjust your nrpe command definition to look like scottwilkerson indicated above.
Adjust your services definitions (services.cfg) to look like this:
Adjust the appropriate lines in your nrpe.cfg on the remote machine to look like this:
Does this make sense?
check_command check_nrpe!check_users
check_command check_nrpe!check_procs
check_command check_procs!250!400!RSZDT
check_command check_nrpe!check_load
check_command check_nrpe!check_swap
!20!10
}Code: Select all
command[check_disk]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /
command[check_users]=/usr/local/nagios/libexec/check_users -w 20 -c 50
command[check_load]=/usr/local/nagios/libexec/check_load -w 5.0,4.0,3.0 -c 10.0,6.0,4.0
command[check_procs]=/usr/local/nagios/libexec/check_procs -w 250 -c 400 -s RSZDT
commnad[check_swap]=/usr/local/nagios/libexec/check_swap -w 20% -c 10%Re: Nagios® Core™ Version 4.0.8
thanks for your reply jdalrymple
now i got this error;
root@dosya:/usr/local/nagios/etc/objects# sudo service nagios restart
Running configuration check...
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'Current Users' on host 'domates.karel.com.tr' (config file '/usr/local/nagios/etc/objects/ubuntu.cfg', starting on line 53)
Checking objects...
Error: Service check command 'check_procs!250!400!RSZDT' specified in service 'Total Processes' for host 'domates.karel.com.tr' not defined anywhere!
Warning: Service 'Current Load' on host 'localhost' has no check time period defined!
Warning: Service 'Current Users' on host 'localhost' has no check time period defined!
Warning: Service 'HTTP' on host 'localhost' has no check time period defined!
Warning: Service 'PING' on host 'localhost' has no check time period defined!
Warning: Service 'Root Partition' on host 'localhost' has no check time period defined!
Warning: Service 'SSH' on host 'localhost' has no check time period defined!
Warning: Service 'Swap Usage' on host 'localhost' has no check time period defined!
Warning: Service 'Total Processes' on host 'localhost' has no check time period defined!
Checked 47 services.
Checked 7 hosts.
Checked 2 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 26 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 7 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 8
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check...
Nagios Core 4.0.8
License: GPL
Checking objects...
Checked 7 hosts.
Checked 1 contacts.
Checked 7 hosts
Total Warnings: 8
Total Errors: 1
also my configuration files under /usr/local/nagios/etc/ is
please find at attachment
Nagios Core 4.0.8
License: GPL
Checking objects...
Checked 7 hosts.
Checked 1 contacts.
Checked 7 hosts
Total Warnings: 8
Total Errors: 1
Nagios Core 4.0.8
License: GPL
Checking objects...
Checked 7 hosts.
Checked 1 contacts.
Checked 7 hosts
Total Warnings: 8
Total Errors: 1
attachment is forgotten
it is added.
it is added.
resource.cfg- (1.28 KiB) Downloaded 529 times
nagios.cfg- (43.57 KiB) Downloaded 534 times
- objects.rar
- (14.86 KiB) Downloaded 367 times
jdalrymple
- Skynet Drone
The service definitions I gave you were intended to replace the ones you already defined. You cannot have multiple services with the same name for the same host.
Please adjust accordingly and post the results.
Thanks for your reply
Could u send me as a example of your object folder and nagios.cfg file?
regards
regards
