Notification command is not being called
[email protected]
Post by [email protected] »
Hi
I'm running "Nagios Core 3.5.1" and I have started having the problem were the notification command is not being executed
Here is the debug trace when the level is set to 32 showing the "Processed notification command"
[1426786468.314493] [032.2] [pid=1742] Processed notification command: /usr/lib64/nagios/plugins/custom/notify_Master.pl -a PROBLEM -b mia.ver.buscat.check_all_ntp_time -c MIA-DMEPXY224 -d 10.7.12.1 -e CRITICAL -f Thu Mar 19 13:34:28 EDT 2015 -g testing if alarms still work -h BENAG01
If I become the nagios user and execute the command by hand(cut and paste), it works.
What in the "Processing of the notification command" would prevent it from actually calling the script ?
Is there some other debug method I could use to determine why it is not being called ?
Any help would be appreciated.
thanks
jdalrymple
Skynet Drone
Re: Notification command is not being called
Post by jdalrymple »
It looks like the notification is being processed. Why it's not actually sending the message for you I'm unsure. That is not the buitlin notify command - although I'm sure you know that. I don't even see it on the exchange so it's likely something you guys wrote in-house. You may have to add some additional debugging to that perl script to figure out why your notification isn't making it from point a to point b.
Just to help the process along - maybe you could tell us about anything that's changed in your environment lately? Nagios config changes? SMTP relay/Exchange modifications?
Also, you might look at selinux - if it's enabled it can cause strange things that should happen to not happen.
[email protected]
selinux was the problem
Thanks again !!
