Nagios NA Update issue
lingweican
Post by lingweican »
Currently my nagios NA is working fine. Is just at the main page the graph usage doesnt update until i hit F5 to refresh the page. compare to the previous version is will auto update the latest graph appearance and show the brief network usage. Is it a bug or is nto inculded ?
Re: Nagios NA Update issue
Post by Box293 »
Have you experienced this behaviour in other web browsers?
lingweican
That I never check but my IE 10 doesn't even load the graph so I left with Firefox but there no known issue right ?
I haven't heard of other users, reporting the same issue but it is possible it is a bug. Do you experience the same problem in compatibility mode in IE?
ssax
Dreams In Code
Post by ssax »
I haven't heard of any reports of this issue either, it's working fine for me in the latest Firefox and Chrome.
Open up the page and wait about 10 minutes, then hit the F12 key, click on Console, then click all of the buttons except for JS and Clear then post the output if there are any javascript warnings/errors.
Note: See the attached image, only the JS one should be blue so it will limit it to just javascript errors.
I tested NA using IE10 on Windows7 64bit and the graphs are updating automatically for me.
Can you clear out all of the settings, cache, etc in IE and if you have any toolbars installed, can you remove them and test this out again?
