I am having problems applying config after trying to add devices using wizard.
I tried to write databases configs to a file and then verify and this is the error I found
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/staging.cfg', starting on line 156)
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
How do i fix it
Problem with applying configuration
Re: Problem with applying configuration
I answered my self. I fixed the problems. I am good now
please close the ticket
