Linux host not sending logs
Gabriel_Barba
I've a problem with linux hosts, since they aren't sending logs to log server, I ran the instalation instructions:
[root@fpS241ch work]# bash /root/setup-linux.sh -s 10.218.108.216 -p 5544
Detected rsyslog 4.6.2
Detected rsyslog work directory /var/spool/rsyslog
Destination Log Server: 10.218.108.216:5544
Creating /etc/rsyslog.d/99-nagioslogserver.conf...
SELinux is disabled.
rsyslog configuration check passed.
Restarting rsyslog service with 'service'...
Shutting down system logger: [ OK ]
Starting system logger: [ OK ]
Okay.
rsyslog is running with the new configuration.
Visit your Nagios Log Server dashboard to verify that logs are being received.
and then created an specific file to be sent
[root@fpS241ch ~]# bash setup-linux.sh -s 10.218.108.216 -p 5544 -f /var/log/maillog -t maillog_108.241
Creating /etc/rsyslog.d/90-nagioslogserver_var_log_maillog.conf...
Okay.
however if I go to log server, there's no information about this host, we are able to see other hosts (not one of them is linux host just network devices).
Can you please help me to find out what I'm missing?
Regards,
Gabriel
Okay.
Okay.
Regards,
Gabriel
- Box293
- Too Basu
Re: Linux host not sending logs
Are you seeing the traffic hit the Nagios Log Server?
Run this on your Nagios Log Server:
Change xxx.xxx.xxx.xxx to be the IP Address of the server sending the logs.
Or if it's UDP traffic:
tcpdump src host xxx.xxx.xxx.xxx and tcp dst port 5544 and dst host 10.218.108.216Or if it's UDP traffic:
tcpdump src host xxx.xxx.xxx.xxx and udp dst port 5544 and dst host 10.218.108.216As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Gabriel_Barba
I've ran the command for 10 minutes each, and can't see any traffic on the Log Server, I see at the server I want to collect logs rsyslog is running:
[root@fpS241ch ~]# service rsyslog status
rsyslogd (pid 31676) is running...
and the file is generating logs:
[root@fpS241ch log]# ll maillog
-rw------- 1 root root 4815851 Mar 23 08:12 maillog
-rw------- 1 root root 4816899 Mar 23 08:14 maillog
I'm missing something?
Regards,
Gabriel
Regards,
Gabriel
What distribution of linux are you running this script on?
I trust that pings work fine from the linux host to the log server?
Are there any firewalls in between that you would need to create an ACL in?
On your Nagios Log Server, is the Logstash port open and listening?
Let us know. Thanks!
cat /etc/*releaseCode: Select all
ping 10.218.108.216On your Nagios Log Server, is the Logstash port open and listening?
netstat -na |grep 5544
iptables -L-
Gabriel_Barba
Here are the outputs:
on the client where we are running the script:
On the log server:
[root@fpS241ch rsyslog.d]# cat /etc/*release
Red Hat Enterprise Linux Server release 6.2 (Santiago)
[root@fpS241ch rsyslog.d]# ping 10.218.108.216
PING 10.218.108.216 (10.218.108.216) 56(84) bytes of data.
64 bytes from 10.218.108.216: icmp_seq=1 ttl=64 time=0.372 ms
[root@fps216ch ~]# netstat -na |grep 5544
tcp 0 0 :::5544 :::* LISTEN
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.167:51283 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.167:55438 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.167:55364 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.167:58272 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.201:33074 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.167:38372 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.167:51282 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.167:58275 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.201:33075 ESTABLISHED
tcp 0 0 ::ffff:10.218.108.216:5544 ::ffff:10.218.108.167:38371 ESTABLISHED
udp 0 0 :::5544 :::*
[root@fps216ch ~]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
[root@fps216ch ~]# cat /etc/*release
CentOS release 6.6 (Final)
Interesting - it doesn't look like iptables is listing any rules in its chain. Could you try turning iptables off on the Nagios Log Server temporarily?
If the logs do not, please turn iptables back on, and let us know the output of the following:
Thank you!
See if the logs start coming in now...service iptables stop
tail /var/log/logstash/logstash.log-
Gabriel_Barba
so... I turned off iptables, and the logs still not in the log server...
went checking to the log server, and nothing is comming (previously waited to see if maillog is creating some data)
[root@fps216ch ~]# service iptables stop
iptables: Setting chains to policy ACCEPT: filter [ OK ]
iptables: Flushing firewall rules: [ OK ]
iptables: Unloading modules: [ OK ]
[root@fps216ch ~]# service iptables start
iptables: Applying firewall rules: [ OK ]
[root@fps216ch ~]# tail /var/log/logstash/logstash.log
[root@fps216ch ~]#
We ran a TCPdump and saw that your NLS was not getting any data from log sources. After that, we turned your firewall off and verified that the log data is still not transmitted. This being the case, the logs are either not being sent from your box, or they are not getting through the network properly.
Just to make certain logstash is fine, let's check that it's up and running properly:
After that, let's go back to your linux box that is sending the logs, and run the following:
If you see traffic being sent, please let us know.
Thank you.
service logstash statusCode: Select all
cat /usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.confCode: Select all
cat /usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.confCode: Select all
cat /etc/sysconfig/logstashCode: Select all
ps -ef |grep logstashCode: Select all
tcpdump -n dst port 5544Thank you.
Gabriel_Barba
Ok, for the first set of instructions here is the output:
on the server that's supposed to send the logs:
[root@fps216ch ~]# service logstash status
Logstash Daemon (pid 1294) is running...
[root@fps216ch ~]# cat /usr/local/nagioslogserver/logstash/etc/conf.d/000_inputs.conf
# Logstash Configuration File
# Dynamically created by Nagios Log Server
# DO NOT EDIT THIS FILE. IT WILL BE OVERWRITTEN.
# Created Mon, 01 Dec 2014 10:37:57 -0500
# Global inputs
input {
syslog {
type => 'syslog'
port => 5544
tcp {
type => 'eventlog'
port => 3515
codec => json {
charset => 'CP1252'
tcp {
type => 'import_raw'
tags => 'import_raw'
port => 2056
tcp {
type => 'import_json'
tags => 'import_json'
port => 2057
codec => json
# Local inputs
[root@fps216ch ~]# cat /usr/local/nagioslogserver/logstash/etc/conf.d/500_filters.conf
# Global filters
filter {
if [program] == 'apache_access' {
grok {
match => [ 'message', '%{COMBINEDAPACHELOG}']
date {
match => [ 'timestamp', 'dd/MMM/yyyy:HH:mm:ss Z' ]
mutate {
replace => [ 'type', 'apache_access' ]
convert => [ 'bytes', 'integer' ]
convert => [ 'response', 'integer' ]
if [program] == 'apache_error' {
grok {
match => [ 'message', '\[(?<timestamp>%{DAY:day} %{MONTH:month} %{MONTHDAY} %{TIME} %{YEAR})\] \[%{WORD:class}\] \[%{WORD:originator} %{IP:clientip}\] %{GREEDYDATA:errmsg}']
mutate {
replace => [ 'type', 'apache_error' ]
# Local filters
[root@fps216ch ~]# cat /etc/sysconfig/logstash
# Default settings for logstash
# Override Java location
#JAVACMD=/usr/bin/java
# Set a home directory
APP_DIR=/usr/local/nagioslogserver
LS_HOME="$APP_DIR/logstash"
# set ES_CLUSTER
ES_CLUSTER=$(cat $APP_DIR/var/cluster_uuid)
# Arguments to pass to java
#LS_HEAP_SIZE="256m"
LS_JAVA_OPTS="-Djava.io.tmpdir=$APP_DIR/tmp"
# Logstash filter worker threads
#LS_WORKER_THREADS=1
# pidfiles aren't used for upstart; this is for sysv users.
#LS_PIDFILE=/var/run/logstash.pid
# user id to be invoked as; for upstart: edit /etc/init/logstash.conf
LS_USER=nagios
LS_GROUP=nagios
# logstash logging
#LS_LOG_FILE=/var/log/logstash/logstash.log
#LS_USE_GC_LOGGING="true"
# logstash configuration directory
LS_CONF_DIR="$LS_HOME/etc/conf.d"
# Open file limit; cannot be overridden in upstart
#LS_OPEN_FILES=2048
# Nice level
#LS_NICE=0
# Increase Filter workers to 4 threads
LS_OPTS=" -w 4"
if [ "x$1" == "xstart" -o "x$1" == "xrestart" -o "x$1" == "xreload" ];then
GET_LOGSTASH_CONFIG_MESSAGE=$( php /usr/local/nagioslogserver/scripts/get_logstash_config.php )
GET_LOGSTASH_CONFIG_RETURN=$?
if [ "$GET_LOGSTASH_CONFIG_RETURN" != "0" ]; then
echo $GET_LOGSTASH_CONFIG_MESSAGE
exit 1
fi
fi[root@fps216ch ~]# ps -ef |grep logstash
root 1292 1 0 2014 ? 00:00:00 runuser -s /bin/sh -c exec /usr/local/nagioslogserver/logstash/bin/logstash agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log -w 4 nagios
nagios 1294 1292 0 2014 ? 02:02:10 /usr/bin/java -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx500m -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -jar /usr/local/nagioslogserver/logstash/vendor/jar/jruby-complete-1.7.11.jar -I/usr/local/nagioslogserver/logstash/lib /usr/local/nagioslogserver/logstash/lib/logstash/runner.rb agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log -w 4
root 54596 48728 0 09:56 pts/1 00:00:00 grep logstash
[root@fpS241ch rsyslog.d]# tcpdump -n dst port 5544
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth4, link-type EN10MB (Ethernet), capture size 65535 bytes
^C
0 packets captured
0 packets received by filter
0 packets dropped by kernel
So far we have determined that nothing is wrong on the NLS side of things. On your Linux host, please check the following settings...
service rsyslogd statusCode: Select all
getenforceCode: Select all
cat /etc/rsyslog.d/*.confCode: Select all
cat /etc/rsyslog.conf
