Same thing happens when I try to do "Apply Configuration."
tail /var/log/messages -n 100 > /tmp/messages_log.txt
tail /var/log/httpd/error_log -n 100 > /tmp/httpd_log.txtCode: Select all
/tmp/httpd_log.txtThank you for the response. Unfortunately, nothing is being logged when I submit the snapshot. Anything else I can look at?Box293 wrote:Go and create a snapshot and then run these commandsSend us these files:Code: Select all
tail /var/log/messages -n 100 > /tmp/messages_log.txt tail /var/log/httpd/error_log -n 100 > /tmp/httpd_log.txtCode: Select all
/tmp/messages_log.txt /tmp/httpd_log.txt
/usr/local/nagioslogserver/var/jobs.logCode: Select all
tail -f /usr/local/nagioslogserver/var/jobs.logCode: Select all
tail -n20 /var/log/cronCode: Select all
# tail /usr/local/nagioslogserver/var/jobs.log
Running command run_alerts with args ' ' for job id: 3qRJYN20Sr27QKUtWg21wg
SUCCESS
SUCCESS
Processed 0 node jobs.
Processed 2 global jobs.Code: Select all
Mar 23 11:22:01 loghost01 crond[5969]: (nagios) FAILED to authorize user with PAM (Permission denied)
Mar 23 11:22:01 loghost01 crond[5970]: (nagios) FAILED to authorize user with PAM (Permission denied)Code: Select all
ser_Alias NAGIOSLOGSERVER=nagios
User_Alias NAGIOSLOGSERVERWEB=apache
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash start
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash stop
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash restart
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash reload
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash status
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch start
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch stop
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch restart
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch reload
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch status
NAGIOSLOGSERVER ALL = NOPASSWD:/usr/local/nagioslogserver/scripts/change_timezone.sh
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash start
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash stop
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash restart
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash reload
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash status
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch start
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch stop
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch restart
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch reload
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch status
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/usr/local/nagioslogserver/scripts/get_logstash_ports.shCode: Select all
# cat nagioslogserver
# /etc/cron.d/nagioslogserver: crontab fragment for nagioslogserver
* * * * * nagios /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1
* * * * * nagios /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1Code: Select all
User_Alias NAGIOSLOGSERVERWEB=apacheCode: Select all
User_Alias NAGIOSLOGSERVER=nagiosCode: Select all
chage -l nagiosCode: Select all
# chage -l nagios
Last password change : Feb 04, 2015
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : 0
Maximum number of days between password change : 99999
Number of days of warning before password expires : 7Code: Select all
#includedir /etc/sudoers.dCode: Select all
vi /etc/sudoersCode: Select all
service elasticsearch restart
service logstash restartCode: Select all
cat /etc/pam.d/crondCode: Select all
sestatus
