manual compile of CGIs and incorrect image/css source
node-nine_inc
Post by node-nine_inc »
Hello.
I'm likely doing something face-palm stupid here, but I'm pretty familiar with the compilation process...yet am stumped where I'm going wrong.
nagios-4.0.8. Just pulled down the latest source of this version. I need to build from source and have been building Nagios from source since back in the 1.x days, so have definitely done this many many many times before.
I'm using the following configure string:
./configure --enable-event-broker --localstatedir=/var/demo.foo.com --sysconfdir=/etc/demo.foo.com --infodir=/var/www/localhost/demo.foo.com/info --mandir=/var/www/localhost/demo.foo.com/man --prefix=/var/www/localhost/demo.foo.com --with-nagios-user=demo.foo.com --with-nagios-grp=apache --with-command-user=demo.foo.com --with-command-grp=apache --datarootdir=/var/www/localhost/demo.foo.com/share --with-htmurl= --with-cgiurl=/cgi-bin
Everything compiles and installs just fine.
The trouble I'm having is that the CGIs are for some reason looking in their local dir (sbin) for the images and CSS files that control their page output/display as opposed to looking in the share/images and share/stylesheets dir as they should.
ex>
=====[ Apache logs of problem
[Fri Mar 20 12:11:15.577821 2015] [cgi:error] [pid 2746] [client x.x.x.x:52356] script not found or unable to stat: /var/www/localhost/demo.foo.com/sbin/status.css, referer: http://demo.foo.com/cgi-bin/status.cgi?host=all
[Fri Mar 20 12:11:15.577821 2015] [cgi:error] [pid 32020] [client x.x.x.x:52354] script not found or unable to stat: /var/www/localhost/demo.foo.com/sbin/common.css, referer: http://demo.foo.com/cgi-bin/status.cgi?host=all
[Fri Mar 20 12:11:15.578049 2015] [cgi:error] [pid 9474] [client x.x.x.x:52357] script not found or unable to stat: /var/www/localhost/demo.foo.com/sbin/jquery-1.7.1.min.js, referer: http://demo.foo.com/cgi-bin/status.cgi?host=all
[Fri Mar 20 12:11:15.651873 2015] [cgi:error] [pid 32020] [client x.x.x.x:52354] script not found or unable to stat: /var/www/localhost/demo.foo.com/sbin/contexthelp1.gif, referer: http://demo.foo.com/cgi-bin/status.cgi?host=all
[Fri Mar 20 12:11:15.651870 2015] [cgi:error] [pid 9474] [client x.x.x.x:52357] script not found or unable to stat: /var/www/localhost/demo.foo.com/sbin/up.gif, referer: http://demo.foo.com/cgi-bin/status.cgi?host=all
[Fri Mar 20 12:11:15.658766 2015] [cgi:error] [pid 2746] [client x.x.x.x:52356] script not found or unable to stat: /var/www/localhost/demo.foo.com/sbin/down.gif, referer: http://demo.foo.com/cgi-bin/status.cgi?host=all
[Fri Mar 20 12:11:15.665647 2015] [cgi:error] [pid 9474] [client x.x.x.x:52357] script not found or unable to stat: /var/www/localhost/demo.foo.com/sbin/ndisabled.gif, referer: http://demo.foo.com/cgi-bin/status.cgi?host=all
This causes the output of all the CGIs to be garbled and missing content since none of the layout or imagery renders.
Has anyone run across this? And if so, can you please smack me upside the head with the clue bat? I'm not seeing where I'm missing what's going on.
rhassing
Re: manual compile of CGIs and incorrect image/css source
Post by rhassing »
Which OS and distribution are you using?
Rob Hassing
node-nine_inc
This particular installation is on a Gentoo Linux system, but I am building entirely from source -vs- using emerge.
Could you run the following in a shell and post back the results?
ll /var/www/localhost/demo.foo.com
ll /var/www/localhost/demo.foo.com/sbin
node-nine_inc
Don't have an 'll' command or alias.
sdca-m5-1 ~ # ll /var/www/localhost/demo.foo.com
-bash: ll: command not found
sdca-m5-1 ~ # ll /var/www/localhost/demo.foo.com/sbin
But assuming you're looking for a long file listing, here it is. I create a separate user to run the process as.
sdca-m5-1 ~ # ls -l /var/www/localhost/demo.foo.com
total 28
drwxrwxr-x  2 demo.foo.com nagios 4096 Mar 19 18:28 bin
drwxr-xr-x  3 root                    root   4096 Mar 19 17:09 include
drwxr-xr-x  2 root                    root   4096 Mar 19 18:28 lib
drwxrwxr-x  2 demo.foo.com nagios 4096 Mar 19 17:19 libexec
drwxr-xr-x  5 root                    root   4096 Mar 19 17:19 perl
drwxrwxr-x  2 demo.foo.com nagios 4096 Mar 19 18:28 sbin
drwxrwxr-x 11 demo.foo.com nagios 4096 Mar 19 18:28 share
sdca-m5-1 ~ # ls -l /var/www/localhost/demo.foo.com/sbin
total 5844
-rwxrwxr-x 1 demo.foo.com nagios 356916 Mar 19 18:28 archivejson.cgi
-rwxrwxr-x 1 demo.foo.com nagios 341452 Mar 19 18:28 avail.cgi
-rwxrwxr-x 1 demo.foo.com nagios 330396 Mar 19 18:28 cmd.cgi
-rwxrwxr-x 1 demo.foo.com nagios 312708 Mar 19 18:28 config.cgi
-rwxrwxr-x 1 demo.foo.com nagios 353696 Mar 19 18:28 extinfo.cgi
-rw-r--r-- 1 demo.foo.com nagios    822 Mar 19 17:33 favicon.ico
-rwxrwxr-x 1 demo.foo.com nagios 300496 Mar 19 18:28 histogram.cgi
-rwxrwxr-x 1 demo.foo.com nagios 279980 Mar 19 18:28 history.cgi
-rwxrwxr-x 1 demo.foo.com nagios 275872 Mar 19 18:28 notifications.cgi
-rwxrwxr-x 1 demo.foo.com nagios 361908 Mar 19 18:28 objectjson.cgi
-rwxrwxr-x 1 demo.foo.com nagios 271756 Mar 19 18:28 outages.cgi
-rwxrwxr-x 1 demo.foo.com nagios 271764 Mar 19 18:28 showlog.cgi
-rwxrwxr-x 1 demo.foo.com nagios 357820 Mar 19 18:28 status.cgi
-rwxrwxr-x 1 demo.foo.com nagios 350740 Mar 19 18:28 statusjson.cgi
-rwxrwxr-x 1 demo.foo.com nagios 300480 Mar 19 18:28 statusmap.cgi
-rwxrwxr-x 1 demo.foo.com nagios 292256 Mar 19 18:28 statuswml.cgi
-rwxrwxr-x 1 demo.foo.com nagios 275884 Mar 19 18:28 statuswrl.cgi
-rwxrwxr-x 1 demo.foo.com nagios 300500 Mar 19 18:28 summary.cgi
-rwxrwxr-x 1 demo.foo.com nagios 288228 Mar 19 18:28 tac.cgi
-rwxrwxr-x 1 demo.foo.com nagios 308696 Mar 19 18:28 trends.cgi
ssax
Dreams In Code
Post by ssax »
Looks like your --with-htmurl= is blank, did you try fixing that and compiling?
node-nine_inc
Whenever I fill that out, I get weird output at the completion summary for configure.
ex>
./configure --enable-event-broker --localstatedir=/var/demo.foo.com --sysconfdir=/etc/demo.foo.com --infodir=/var/www/localhost/demo.foo.com/info --mandir=/var/www/localhost/demo.foo.com/man --prefix=/var/www/localhost/demo.foo.com --with-nagios-user=demo.foo.com --with-nagios-grp=apache --with-command-user=demo.foo.com --with-command-grp=apache --datarootdir=/var/www/localhost/demo.foo.com/share --with-htmurl=http://demo.foo.com --with-cgiurl=/cgi-bin
ends up outputting the following when it completes:
*** Configuration summary for nagios 4.0.8 08-12-2014 ***:
 General Options:
        Nagios executable:  nagios
        Nagios user/group:  demo.foo.com,nagios
       Command user/group:  demo.foo.com,nagios
             Event Broker:  yes
        Install ${prefix}:  /var/www/localhost/demo.foo.com
    Install ${includedir}:  /var/www/localhost/demo.foo.com/include/nagios
                Lock file:  /var/demo.foo.com/nagios.lock
   Check result directory:  /var/demo.foo.com/spool/checkresults
           Init directory:  /etc/init.d
  Apache conf.d directory:  /etc/httpd/conf.d
             Mail program:  /usr/bin/mail
                  Host OS:  linux-gnu
          IOBroker Method:  epoll
 Web Interface Options:
                 HTML URL:  http://localhosthttp://demo.foo.com/
                  CGI URL:  http://localhost/cgi-bin/
 Traceroute (used by WAP):  /usr/bin/traceroute
Review the options above for accuracy.  If they look okay,
type 'make all' to compile the main program and CGIs.
If I leave out the http portion, I still see weird outputs:
./configure --enable-event-broker --localstatedir=/var/demo.foo.com --sysconfdir=/etc/demo.foo.com --infodir=/var/www/localhost/demo.foo.com/info --mandir=/var/www/localhost/demo.foo.com/man --prefix=/var/www/localhost/demo.foo.com --with-nagios-user=demo.foo.com --with-nagios-grp=apache --with-command-user=demo.foo.com --with-command-grp=apache --datarootdir=/var/www/localhost/demo.foo.com/share --with-htmurl=demo.foo.com --with-cgiurl=/cgi-bin
results in:
 General Options:
             Event Broker:  yes
                  Host OS:  linux-gnu
                 HTML URL:  http://localhostdemo.foo.com/
In the past, all my custom compile versions (from 3.x back down to 1.x) I've always left the html-url portion blank and it has worked appropriately.
ssax
Dreams In Code
Post by ssax »
Looks like this will work:
--with-htmurl='/'
Referenced from here:
https://github.com/NagiosEnterprises/na ... t-50787682
node-nine_inc
Sadly still no dice.
nagios-4.0.8 # ./configure --enable-event-broker --localstatedir=/var/demo.foo.com --sysconfdir=/etc/demo.foo.com --infodir=/var/www/localhost/demo.foo.com/info --mandir=/var/www/localhost/demo.foo.com/man --prefix=/var/www/localhost/demo.foo.com --with-nagios-user=demo.foo.com --with-nagios-grp=apache --with-command-user=demo.foo.com --with-command-grp=apache --datarootdir=/var/www/localhost/demo.foo.com/share --with-htmurl='/' --with-cgiurl=/cgi-bin
 General Options:
             Event Broker:  yes
                  Host OS:  linux-gnu
                 HTML URL:  http://localhost//
The CGIs still end up looking in the /cgi-bin/ location for their related .css and .png files (which is the sbin folder).
demo.foo.com 68.8.82.222 - - [25/Mar/2015:15:12:47 -0700] "GET /cgi-bin/tac.cgi HTTP/1.1" 200 12423 "http://demo.foo.com/side.php" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:36.0) Gecko/20100101 Firefox/36.0" VLOG=-
demo.foo.com 68.8.82.222 - - [25/Mar/2015:15:12:47 -0700] "GET /cgi-bin/common.css HTTP/1.1" 404 289 "http://demo.foo.com/cgi-bin/tac.cgi" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:36.0) Gecko/20100101 Firefox/36.0" VLOG=-
demo.foo.com 68.8.82.222 - - [25/Mar/2015:15:12:47 -0700] "GET /cgi-bin/tac.css HTTP/1.1" 404 286 "http://demo.foo.com/cgi-bin/tac.cgi" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:36.0) Gecko/20100101 Firefox/36.0" VLOG=-
demo.foo.com 68.8.82.222 - - [25/Mar/2015:15:12:47 -0700] "GET /cgi-bin/contexthelp2.gif HTTP/1.1" 404 295 "http://demo.foo.com/cgi-bin/tac.cgi" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:36.0) Gecko/20100101 Firefox/36.0" VLOG=-
demo.foo.com 68.8.82.222 - - [25/Mar/2015:15:12:47 -0700] "GET /cgi-bin/thermok.png HTTP/1.1" 404 290 "http://demo.foo.com/cgi-bin/tac.cgi" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:36.0) Gecko/20100101 Firefox/36.0" VLOG=-
demo.foo.com 68.8.82.222 - - [25/Mar/2015:15:12:47 -0700] "GET /cgi-bin/tacenabled.png HTTP/1.1" 404 293 "http://demo.foo.com/cgi-bin/tac.cgi" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:36.0) Gecko/20100101 Firefox/36.0" VLOG=-
demo.foo.com 68.8.82.222 - - [25/Mar/2015:15:12:47 -0700] "GET /cgi-bin/thermcrit.png HTTP/1.1" 404 292 "http://demo.foo.com/cgi-bin/tac.cgi" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.7; rv:36.0) Gecko/20100101 Firefox/36.0" VLOG=-
I'd even tried copying these .css and .png files to the location being referenced, but seeing as how this it the ScriptAlias cgi-bin folder, I then get errors about 'unable to execute' for these files.
Something is still amiss.
node-nine_inc
+ssax
I finally read the whole bug report you linked to. Manually setting the 'url_html_path' value in cgi.cfg did the trick.
I cannot thank you enough for helping me find this!!!!!!!!! I've been pulling out my little remaining hair trying to find what option was mistaken causing the URL pathing to be incorrect.
Your linked bug-report saved the day.
Cheers mate. If you're ever out in the San Diego California area...hit me up and I owe you a couple sudsy malted hops beverages. :)
