Hi all
I have Nagios core 4 running at my office. I have a Raspberry Pi at my home with NRPE on it. I can run the command on the Nagios server at the office to query the Pi and I get back the version of the NRPE, so I know at least that much is working.
I used this tutorial to get NRPE running on the Pi.
http://www.tecmint.com/how-to-add-linux ... ng-server/
When I run this command
/usr/local/nagios/libexec/check_nrpe -H localhost -c check_load
I get NRPE: Unable to read output.
Does anyone have any ideas what commands I need to use? I installed the NRPE-plugins and restarted NRPE
Thanks for any ideas you can share
Noob needs commands to monitor a Raspberry Pi
Re: Noob needs commands to monitor a Raspberry Pi
Can you perform the check local on the PI?
Rob Hassing
The command I mentioned was from the Pi
- Box293
- Too Basu
On your Pi, a command is defined for "check_load".
This will be in:
/usr/local/nagios/etc/nrpe.cfg
or
/usr/local/nagios/etc/nrpe/common.cfg
How is this command defined?
What is the output of the command when run as the nagios user on the remote host?
This will be in:
or
