Action Command
monitoreo1
Action Command
Post by monitoreo1 »
Que tal necesito su ayuda para poder ejecutar un Action Command , tengo la siguinete instrucción:
/usr/local/nagios/libexec/check_nrpe -H $HOSTADDRESS$ -c stop_lzic -t 99
Al ejecutarla desde línea de comandos si se ejecuta correctamete pero, al crear un Action Component de tipo Command con variables no me funciona
/usr/local/nagios/libexec/reset_lzic.sh "%hostaddress%"
Como podría pasar al Action Component
La version es:
Nagios XI Version : 2014R2.6
x86_64
Red Hat Enterprise Linux Server release 7.0 (Maipo)
Gnome esta instalado
Re: Action Command
Por favor, escribe sus preguntas en inglés para que los otros pueden leerlos.
monitoreo1 wrote:Hey I need your help to be able to execute an Action Command, I have the following command:
When I run this command it works fine, however when I create an Action Component of the type "Command" with variables it does not work for me
How can pass this to the Action Component?
The version is:
x86_64
Gnome is installed
If you change the script to be '/bin/echo "%hostaddress" > /tmp/address' what is written to the file when you run the command?
Edit: I sent him some as-of-yet unpublished docs on how to integrate SSH links in Windows. It should be published in the near future.
monitoreo1
Re: Action Command
Muchas gracias hemos resuelto el tema de este post.
Saludos !!!
Re: Action Command
monitoreo1 wrote:Thank you very much we have resolved the topic of this post
Greetings !!!
You are quite welcome! I'll be closing this thread now, but feel free to open another if you need anything in the future!
