Create nagios scripts and not showing on web interfaces
pianunix
Post by pianunix »
Today i have created my own bash scripts and adding this into nagios monitoring, but some how this result wont show up in nagios web interfaces, but when i execute the scripts was running with successfull.
:~# /usr/lib/nagios/plugins/check_nrpe -H server45026x -c usedspace_bash
OK - 33% of disk space used.
Can anyone know how to solve this problem ?
Re: Create nagios scripts and not showing on web interfaces
pianunix wrote:but some how this result wont show up in nagios web interfaces, but when i execute the scripts was running with successfull.
What do you mean by this? Did you create a service definition for it? If not, it will neither be visible nor running. If you do have configs please post them.
pianunix
Post by pianunix »
Service description already added, but still wont show on the web interfaces
file.cfg
        host_name                      xxxxxxxxxxxxxxxxx
        service_description             Custom Disk
        check_command                   check_nrpe_1arg!usedspace_bash
and sorry the hostname i change it.
command.cfg
        command_name    usedspace_bash
        command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -c usedspace_bash
ssax
Dreams In Code
Post by ssax »
Looks like you need to modify your service check_command:
            check_command                   usedspace_bash
pianunix
Post by pianunix »
This problem has been fixed, and the solution fixed the command.cfg because they has the same command at usedspace_bash.
ssax
Dreams In Code
Post by ssax »
I'm glad that helped you out, I'll be marking the ticket as resolved and locking the ticket now.
