Show Alert in Dashboard not working
I am an alert setup based on a query. The alerting is working and I am able to get the alerts in XI via NRDP. However when I click on the "show alert in dashboard", it is not showing the dashboard with all the filters. It only shows the time filter? Please advise.
The filtering after clicking on "show alert in dashboard" This is the saved query that I based the alert on The alert dashboard showing the error/warning
Re: Show Alert in Dashboard not working
The symptoms are the same on my lab machine. I will do additional testing and update once more letting you know the status of this potential bug. Thanks!
I upgraded my lab box to the latest revision and this worked properly. I went through our revision history and found:
This bug has been fixed in our latest revision. When the next version of Nagios Log Server is released, please upgrade to it, which will fix this problem. Thanks!Fix load query when clicking through an alert -JO
OK Thanks. Is there an ETA when will that be available?
I also noticed that even though the Check interval was set to 5mins, it was not refreshing or checking. So it is still saying warning right now. When I clicked on Run the alert now, then it turned back to green. Is something stuck and it is not checking within LS?
Regarding the ETA: I am not aware of a release date.
Alerts are picked up by an internal cronjob. Please tail the following log:
Please note that you will have to run this tail on every node in your cluster, as 'global jobs' are only picked up on one node.
Also note that you need to keep this tail following, since jobs.log is truncated often.
You should see a command called 'run_alerts' happen roughly once per minute. Let us know if you do not. It will look something like this:
If you force the run_all_alerts job from the 'command subsystem' what do you see in jobs.log? Does it change? If you run the alert manually from the 'alerts' page, does it affect jobs.log?
Let us know. Thanks!
tail -f /usr/local/nagioslogserver/var/jobs.logAlso note that you need to keep this tail following, since jobs.log is truncated often.
Running command run_alerts with args ' ' for job id: run_all_alertsLet us know. Thanks!
OptimusB,
I spoke with the developers about this case - they have supplied me with a file to correct this issue.
Download the attached file and extract 'logserver.js'.
Login to each node in your NLS cluster, and move the existing /var/www/html/nagioslogserver/www/app/dashboards/logserver.js to some place safe:
Place the new 'logserver.js' file in /var/www/html/nagioslogserver/www/app/dashboards/ on each node in your cluster. You may have to restart httpd:
Once this is complete, please log in to your NLS web GUI and attempt to access your query through the 'Alerts' tab. You may have to clear out your cache for the change to take.
Thanks, let me know if the above works for you!
mv /var/www/html/nagioslogserver/www/app/dashboards/logserver.js /root/backupCode: Select all
service httpd restartThanks, let me know if the above works for you!
I have replaced the logserver.js file on both nodes and the "show alert in dashboard" is now working.
However, keeping an eye on jobs.log, doesn't seem like anything is running.
I just get this on both nodes...
Here's what the Cron log looks like
Processed 0 node jobs.
Processed 0 global jobs.
tail: /usr/local/nagioslogserver/var/jobs.log: file truncated
Mar 25 08:34:01 kdcbchngols01 CROND[29871]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 25 08:34:01 kdcbchngols01 CROND[29870]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 25 08:35:01 kdcbchngols01 CROND[29965]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Mar 25 08:35:01 kdcbchngols01 CROND[29967]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 25 08:36:01 kdcbchngols01 CROND[30060]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1)
Mar 25 08:36:01 kdcbchngols01 CROND[30062]: (nagios) CMD (/usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1)
Your cron log looks fine - poller and jobs are executing every minute. Did you try to force any jobs while you were tailing jobs.log? Were you sure to tail it on every node in your cluster?
Are your backups working properly? Backup are initiated in a similar way to alerts, it would be strange if alerts were not working and backups were.
Let me know. Thanks!
I am tailing both nodes and so far nothing.... I saw this...
However when I click on "run this alert now", nothing shows on the job.log file. Backups are running fine. I just ran one manually and got this entry.
Running command cleanup with args ' ' for job id: cleanup_cmdsubsys
SUCCESS
Processed 1 global jobs.
Running command do_backups with args ' ' for job id: backups
SUCCESS
Processed 1 global jobs.Re: Show Alert in Dashboard not working
Could you please navigate to NLS > Administration > Command Subsystem and initiate the 'Reset All Jobs' command? After this, try tailing jobs.log on both nodes and forcing a 'run_all_alerts' command from the GUI. Perhaps something got messed up when your NLS storage ran out - resetting your jobs could help fix this problem.
