Alert not triggered
wiproltdwiv
Alert not triggered
Post by wiproltdwiv »
Dear Team,
We are using NAGIOS XI 2012 R2.2 .
We have configured the errpt_log parameter in Nagios. We are getting error alerts for all types of errors but for the given below errors alerts are not triggering. Kindly find me the way out, what would be the issue?? Do we need to change anything in error_log script ??
E86653C3   0322061615 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0322061315 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0322060115 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0322055715 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0322025515 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0322024815 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0322024715 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0322023515 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0322023415 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301140215 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301135915 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301134515 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301131615 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301125915 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301124115 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301123515 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301123015 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301121415 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301120415 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301120015 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301112315 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301111215 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301110215 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0301105715 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201154915 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201154315 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201151515 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201142815 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201142715 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201140015 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201132815 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201132015 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201131515 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201125815 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201124815 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201124215 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201114215 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201111415 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201105715 P H LVDD           I/O ERROR DETECTED BY LVM
E86653C3   0201104915 P H LVDD           I/O ERROR DETECTED BY LVM
Please find the error_log script below and let me know if we have to do any changes in that script to get this ( E86653C3) error alert.
#!/bin/sh
#This script is to check the new errors in errpt logs.  Whenever the new error comes, it will trigger alert.
#Binu Mathew : 04-02-2013
errpt > /var/adm/ras/errptnew.log
diff /var/adm/ras/errptorg.log /var/adm/ras/errptnew.log  > /var/adm/ras/errptdiff.log
error=`grep ">" /var/adm/ras/errptdiff.log |uniq| awk '{print $2}'`
count=`grep ">" /var/adm/ras/errptdiff.log |uniq| awk '{print $2}'|wc -l`
#cat /var/adm/ras/errptnew.log > /var/adm/ras/errptorg.log
if [ $count -gt 0 ];then
        echo "$count error `echo $error` found in errpt log"
        STATE=2
else
        echo "OK"
        STATE=0
fi
exit $STATE
#mv /var/adm/ras/errptnew.log /var/adm/ras/errptorg.log
Reason: Please use code wraps for code or terminal output
ssax
Dreams In Code
Re: Alert not triggered
Post by ssax »
Please compress the three files and PM them to me.
wiproltdwiv
Please find the attached files.
It seems like you are not getting alerted as the "errptorg.log" and the "errptnew.log" are the same - there are no new errors. The "errptdiff.log" is empy, so the script will exit with STATE=0...
