Nagios XI r2.5
Redhat el6
I was trying to figure out a way to do this, but since we use the NCPA agent the METRICS funtionality is useless to us at this point. (Hoping that is going to change soon?)
Is there a way to create a Top 10 of say Windows C: and place it in a view or dashboard?
May be a stupid question as I may be missing something obvious.
Any input or suggestion would be most helpful!
Top X dashboards/views for CPU Memory etc..
krobertson71
Re: Top X dashboards/views for CPU Memory etc..
NCPA data is currently not included in the METRICS component. There is an internal feature request already created.
krobertson71
Is there another way to achieve this, or is this strictly a metrics function?
This is pretty much restricted to metrics in XI unfortunately.
krobertson71
You can close this thread. This was discussed in another and added was told this was in the works.
