Browser doesn't reload
Hi all.
Nagios page doesn't reload in any browser.
I have tried in IE, firefox and chrome and the system operation is windows 7 32bits.
I need to keep pressing <F5> every time that I need to check for any change.
Can anyone help me on this??
Fabiano.
Fabiano.
grittyminder
Re: Browser doesn't reload
You can set the client browser refresh rate (in seconds) by changing the value of refresh_rate in /usr/local/nagios/etc/cgi.cfg
I have the same problem with becatini here.
My browser did not load properly, but it is work on other programs just fine.
I try to follow the instruction but comes up with no good result.
Please help.
Please help.
Ive also had this problem! Anyone got any ideas?
Much appreciated.
Much appreciated.
There are a number of things that may be in play here, including the possibility that auto-refreshes may not be enabled on the browser in question. Making sure that the proper option (refresh_rate=90) is set in the cgi.cfg file is a good place to start. Restarting the Nagios instance is not required for changes to cgi.cfg.
Beyond that, one will need to perform a packet trace to get a look at the HTTP response headers from the server where the CGIs run and look for a string like: "Refresh: 90\r\n". If that string is there and the browser isn't refreshing then the browser is misbehaving; if the string is NOT there, then the configuration of the web-server needs to be checked as it's not transmitting the command to perform an auto-refresh.
I have also been having the same problem. Thanks for the ideas, they worked fine for me.
calderetaz
mikevedaya
