gabrielsousa
Posts: 20 Joined: Mon Mar 02, 2015 5:06 am
Post
by gabrielsousa » Thu Mar 26, 2015 1:00 pm
can some one help me with this error.
ndo2db:Support for the specified database server is either not yet supported, or was not found on your system.
done.
nagios 4.0.8
ndo2db_user=nagios
ndo2db_group=nagios
#socket_type=tcp
socket_type=unix
socket_name=/var/run/ndo.sock
tcp_port=5668
db_servertype=mysql
db_host=127.0.0.1
db_name=centreon_status
db_port=3306
db_prefix=nagios_
db_user=centreon
db_pass=centreon
max_timedevents_age=1440
max_systemcommands_age=1440
max_servicechecks_age=1440
max_hostchecks_age=1440
max_eventhandlers_age=1440
jolson
Attack Rabbit
Posts: 2560 Joined: Thu Feb 12, 2015 12:40 pm
Post
by jolson » Thu Mar 26, 2015 2:19 pm
What server distribution and version of Nagios Core are you using? Have you tried the troubleshooting mentioned in this thread?
http://support.nagios.com/forum/viewtop ... =7&t=26124
Twits Blog
gabrielsousa
Post
by gabrielsousa » Thu Mar 26, 2015 2:28 pm
FEDORA 12 - nagios core 4.0.8 - ndoutils-2.0.0
and i did try that the that thread with no succes
jdalrymple
Skynet Drone
Posts: 2620 Joined: Wed Feb 11, 2015 1:56 pm
Post
by jdalrymple » Thu Mar 26, 2015 2:31 pm
Is selinux disabled? If not, please disable it and try again.
gabrielsousa
Post
by gabrielsousa » Thu Mar 26, 2015 2:35 pm
jdalrymple wrote: Is selinux disabled? If not, please disable it and try again.
[root@ns1 ~]# getenforce
Disabled
gabrielsousa
Post
by gabrielsousa » Thu Mar 26, 2015 2:42 pm
and i did try that thread with no succes
jdalrymple
Skynet Drone
Post
by jdalrymple » Thu Mar 26, 2015 2:51 pm
Do you still have your config.log from when you compiled ndoutils? If so let's see it.
gabrielsousa
Post
by gabrielsousa » Thu Mar 26, 2015 2:59 pm
jdalrymple wrote: Do you still have your config.log from when you compiled ndoutils? If so let's see it.
yes i have
config.log
(62.85 KiB) Downloaded 415 times
jdalrymple
Skynet Drone
Post
by jdalrymple » Thu Mar 26, 2015 3:09 pm
Then configure, make, make install again
gabrielsousa
Post
by gabrielsousa » Thu Mar 26, 2015 3:17 pm
with this option ?
./configure --prefix=/usr/local/nagios/ --enable-mysql --with-mysql-lib=/usr/lib/mysql --with-ndo2db-user=nagios --with-ndo2db-group=nagios
