Apply configuration succeeds but doesn't
bgmncwj
Post by bgmncwj »
Whenever I go to change a service configuration (either in Core Config Manager or outside of it) when I go to apply the configuration it doesn't return any errors however the change isn't applied. After clicking Apply Configuration and returning to the services section of CCM it still shows "Changes detected! Apply configuration for new changes to take effect". Any ideas? We're running Nagios XI 2014R2.6 on a CentOS 7 machine (64bit), nothing really special about our install.
Re: Apply configuration succeeds but doesn't
Can you run the "reconfigure_nagios.sh" script from the command line successfully? Do you see any errors?
./reconfigure_nagios.sh
bgmncwj
Post by bgmncwj »
No errors besides some certificate warnings from wget, but I see everything runs with --no check-certificate so that shouldn't be the problem.
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
	Checked 807 services.
	Checked 81 hosts.
	Checked 2 host groups.
	Checked 0 service groups.
	Checked 6 contacts.
	Checked 2 contact groups.
	Checked 124 commands.
	Checked 13 time periods.
	Checked 0 host escalations.
	Checked 81 hosts
	Checked 0 host dependencies
	Checked 13 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
RET: 0
Restarting nagios (via systemctl):                         [  OK  ]
Run the following command to begin capturing log output:
tail -f /usr/local/nagiosxi/var/cmdsubsys.log &> /tmp/cmd.txt
Attempt to Apply Configuration from the web interface. After the browser has returned some output to the screen, press "Ctrl+c" to stop the log tail, and post the "cmd.txt" file that was generated in the "/tmp/" directory by the above instructions.
bgmncwj
Post by bgmncwj »
Here's the output you requested
......................................PROCESSING COMMAND ID 3816...
Setting new htaccess credentials
Updating password for user chad.jannusch
OUTPUT=
RETURNCODE=0
...............PROCESSING COMMAND ID 3817...
PROCESS COMMAND: CMD=17, DATA=
APPLYING NAGIOSCORE CONFIG...
CMDLINE=cd /usr/local/nagiosxi/scripts && ./reconfigure_nagios.sh
URL: https://localhost/nagiosxi/includes/components/ccm/
CMDLINE
--2015-03-27 08:04:54--  https://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:443... connected.
WARNING: cannot verify localhost's certificate, issued by ‘/C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./OU=http://certs.godaddy.com/repository//CN=Go Daddy Secure Certificate Authority - G2’:
  Unable to locally verify the issuer's authority.
WARNING: no certificate subject alternative name matches
	requested host name ‘localhost’.
Length: unspecified [text/html]
Saving to: ‘nagiosql.login’
     0K ..........                                              991K=0.01s
2015-03-27 08:04:55 (991 KB/s) - ‘nagiosql.login’ saved [10422]
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=mhfekk' -O nagiosql.loginLOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: https://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
SETUID ROOT OK
CMDLINE
--2015-03-27 08:04:55--  https://localhost/nagiosxi/includes/components/ccm/
     0K ..........                                              945K=0.01s
2015-03-27 08:04:55 (945 KB/s) - ‘nagiosql.login’ saved [10422]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies https://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
Saving to: ‘nagiosql.export.monitoring’
     0K .......... ..                                          24.1K=0.5s
2015-03-27 08:04:56 (24.1 KB/s) - ‘nagiosql.export.monitoring’ saved [13278]
OUTPUT:
Nagios Core 4.0.8
License: GPL
Checking objects...
	Checked 81 hosts.
	Checked 6 contacts.
	Checked 81 hosts
Total Warnings: 0
Total Errors:   0
RET: 0
OUTPUT=Restarting nagios (via systemctl):  [  OK  ]
RETURNCODE=0
abrist
Red Shirt
Post by abrist »
Lets check for multiple nagios parent processes:
ps -aef | grep nagios.cfg
Do the new services appear in the core UI? (browse to http://<server>/nagios/)
bgmncwj
Post by bgmncwj »
Hi abrist,
The service doesn't appear in the core UI. Here's the output from that command:
nagios   16672     1  0 08:04 ?        00:00:27 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   16746 16672  0 08:04 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
Is SELinux enabled on this machine?
getenforce
If it is, disable it:
setenforce 0
and try to apply configuration again.
bgmncwj
Post by bgmncwj »
Doesn't look like SELinux is enabled
[root@nagios ~]# getenforce
Disabled
cmerchant
Post by cmerchant »
Go to CCM --> Tools --> write config files, Click delete , Click write , and Click verify and then do the apply.
