Nagios is not generating alerts for a certain time. For this I have checked frontend setting under alerts setting tab for the notification enable and notification option all are correct.
in our case alerts are not generating between 12 pm to 2 pm every day and after then alerts are generating properly, Is there any setting need to be change pls suggest as soon as possible. This issue is for all domain like Network/AIX/oracle/windows etc.
For this I have checked mysqld logs and Nagios logs. Under mysqld log there is no any such error but in Nagios.log I am getting this warning messages:
Warning: The check of service '*****' on host '*******' looks like it was orphaned (results never came back). I'm scheduling an immediate check of the service...
Note: To resolve this error log I have solution so this may be the issue for not generating alerts. Pls suggest.
please find the alerts snap for two days and see the time variation :
Branch Network | 2015-03-26 11:47:53 | | Branch Network | 2015-03-27 12:00:13 |
| Branch Network | 2015-03-27 12:00:19 |
| Branch Network | 2015-03-27 12:00:25 |
| Branch Network | 2015-03-27 12:00:31 |
| Branch Network | 2015-03-27 12:00:34 |
| Branch Network | 2015-03-27 12:00:46 |
| Branch Network | 2015-03-27 12:00:52 |
| Branch Network | 2015-03-27 14:30:51 |
| Branch Network | 2015-03-27 14:30:52 |
| Branch Network | 2015-03-27 14:30:54 |
| Branch Network | 2015-03-27 14:30:55 |
| Branch Network | 2015-03-27 14:30:56 |
| Branch Network | 2015-03-27 14:30:57 |
| Branch Network | 2015-03-27 14:30:59 |
| Branch Network | 2015-03-27 14:31:02 |
| Branch Network | 2015-03-27 14:31:03 |
| Branch Network | 2015-03-27 14:31:12 |
| Branch Network | 2015-03-27 14:31:17 |
| Branch Network | 2015-03-27 14:31:27 |
| Branch Network | 2015-03-26 11:47:59 |
| Branch Network | 2015-03-26 11:48:02 |
| Branch Network | 2015-03-26 11:48:11 |
| Branch Network | 2015-03-26 11:48:18 |
| Branch Network | 2015-03-26 11:48:21 |
| Branch Network | 2015-03-26 11:48:23 |
| Branch Network | 2015-03-26 11:53:25 |
| Branch Network | 2015-03-26 11:53:26 |
| Branch Network | 2015-03-26 14:58:28 |
| Branch Network | 2015-03-26 14:58:29 |
| Branch Network | 2015-03-26 14:58:30 |
| Branch Network | 2015-03-26 14:58:32 |
| Branch Network | 2015-03-26 14:58:36 |
| Branch Network | 2015-03-26 14:58:42 |
| Branch Network | 2015-03-26 14:58:44 |
| Branch Network | 2015-03-26 14:58:48 |
| Branch Network | 2015-03-26 14:58:51 |
alerts not generating
Re: alerts not generating
You may be experiencing a resource usage spike daily that is causing the orphaned check issues. Please check your XI server's settings aginst those listed in teh FAQ:
http://support.nagios.com/wiki/index.ph ... g_Orphaned
