Centus VM running 20011R1.7, around 550 hosts and 2800 services. Sever load between 3to 5, cpu idle around 50%.
Latency is very low, average 0.1s
But the interface is slow, loading tactical overview or host groups takes forever. I tried switching to unified pages and the problem is fixed, but its like use the regular nagios interface.
Any recommendation ?
Ilo
nagiosxi very slow loading dashboard/tactical overview
Re: nagiosxi very slow loading dashboard/tactical overview
These links will provide you with some information on the steps you can take to boost the Nagios XI performance:
http://assets.nagios.com/downloads/nagi ... rmance.pdf
http://assets.nagios.com/downloads/nagi ... giosXI.pdf
http://assets.nagios.com/downloads/nagi ... Server.pdf
no luck..i followed the document, load now is lower, below 2, cpu idle 70%, database came clean. But the only way to improve tactical overview loading time is switching the page setting to unified.
What version of XI are you using? Are you using NAT, Proxy, or SSL on this system?
