Error Applying Configuration
cdrussell
Post by cdrussell »
'BSWSNMIDP02.swntdomain.sw.org'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/BSWSNMIDP02.swntdomain.sw.org.cfg', starting on line 14)
directives and data defintions.
Re: Error Applying Configuration
What XI version is this?
mp4783
Post by mp4783 »
Can you post the relevant portion of the cfg file?
cdrussell
Post by cdrussell »
2012R2.9
cdrussell
Post by cdrussell »
# Host configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2015-03-27 10:04:57
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
define host {
host_name BSWSNMIDP02.swntdomain.sw.org
address 10.130.24.88
register 1
# END OF FILE
If you edit this host in Core Config Manager and add a template to that host, that should fix the issue. If you have a template setup for that server type.
If you don't have a template, you will have to edit the host and go through all of the tabs and fill in the defaults.
cdrussell
Post by cdrussell »
Thanks everyone that was my issue.
cmerchant
Post by cmerchant »
We'll go ahead and close the thread. Thanks.
