Verify Configuration Bug?
rajasegar
Post by rajasegar »
Even though there are warnings generated the summary shows Warning as 0.
Please check and advice.
Warning: Duplicate definition found for service 'Memory: Physical' on host 'MYWWBRODYSAPP01' (config file '/usr/local/nagios/etc/services/Win_Standard_CIMB_Memory_Physical.cfg', starting on line 16)
Warning: Duplicate definition found for service 'Memory: Physical' on host 'MYWWBPODYSWEB01' (config file '/usr/local/nagios/etc/services/Win_Standard_CIMB_Memory_Physical.cfg', starting on line 16)
Warning: Duplicate definition found for service 'Memory: Physical' on host 'MYWWBPODYSAPP01' (config file '/usr/local/nagios/etc/services/Win_Standard_CIMB_Memory_Physical.cfg', starting on line 16)
Checking objects...
Checked 13696 services.
Checked 1789 hosts.
Checked 209 host groups.
Checked 11 service groups.
Checked 154 contacts.
Checked 46 contact groups.
Checked 175 commands.
Checked 73 time periods.
Checked 0 host escalations.
Checked 1789 hosts
Checked 706 service dependencies
Checked 0 host dependencies
Checked 73 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
Re: Verify Configuration Bug?
What Core version is this?
/usr/local/nagios/bin/nagios --version
rajasegar
Post by rajasegar »
tmcdonald wrote:What Core version is this?
[nagios@nagiosprodxi1 perfdata]$ /usr/local/nagios/bin/nagios --version
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License version 2 as
published by the Free Software Foundation.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
RHEL 6 & 7
jdalrymple
Skynet Drone
Post by jdalrymple »
rajasegar - I'm going to file this bug with our core dev team. there are some other issues with the error checking routine that it can be glommed onto.
Is this one in particular causing any operational problems or is it just a visual distraction?
rajasegar
Post by rajasegar »
jdalrymple wrote:rajasegar - I'm going to file this bug with our core dev team. there are some other issues with the error checking routine that it can be glommed onto.
I had a log file check for the warning parameter.
Noticed it was not working. No operational problems but helps to detect wrong configurations.
RHEL 6 & 7
ssax
Dreams In Code
Post by ssax »
Thank you for reporting this, I have verified it is happening on mine as well. I'm going to mark this as resolved and lock the ticket, feel free to create a new one if you find any more or run into additional issues.
