Cisco Switch Logs
Cisco Switch Logs
Not receiving logs from Cisco Switch. I followed the link below for step one:
http://assets.nagios.com/downloads/nagi ... Server.pdf
Then I added the following:
syslog {
type => 'syslog'
port => 514
Still not seeing any logs from my switch which I configured with:
logging trap debugging
logging source-interface Vlan11
logging 10.x.x.x (IP address of Log server)
I can ping the log server from the switch.
SWT#ping 10.x.x.x
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 10.x.x.x, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
SWT#
syslog {
type => 'syslog'
port => 514
SWT#ping 10.x.x.x
SWT#
Re: Cisco Switch Logs
Have you followed this document? http://assets.nagios.com/downloads/nagi ... Server.pdf
You will need to setup Logstash to run as root - otherwise it cannot listen on ports below 1024. Thank you!
Best,
Jesse
Best,
Jesse
Yes I followed step 1 in the document. How can I verify this action took effect?
Also just noticed that I have the following message with a red ! point at the top saying "Log Collector (logstach) is stopped". I clicked on that and started it but it comes back stopped again.
To verify that Logstash is running as root, please run the following command:
The output should look something like the following:
ps aux | grep logstash |egrep -v "grep"|grep javaPlease note the running user in the upper-left corner of the log. My running-user is nagios. Thanks!nagios 30791 0.6 10.9 1572788 224224 ? SNsl Mar26 48:37 /usr/bin/java -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx500m -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -jar /usr/local/nagioslogserver/logstash/vendor/jar/jruby-complete-1.7.11.jar -I/usr/local/nagioslogserver/logstash/lib /usr/local/nagioslogserver/logstash/lib/logstash/runner.rb agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log -w 4
[root@localhost ~]# ps aux | grep logstash |egrep -v "grep"|grep java
[root@localhost ~]#
[root@localhost ~]#
Is Logstash running?
If not - please start it:
Retry the grep command:
Thank you!
service logstash statusCode: Select all
service logstash startCode: Select all
ps aux | grep logstash |egrep -v "grep"|grep javaRe: Cisco Switch Logs
root 1746 96.5 6.0 1490032 124576 pts/0 SNl 16:14 0:11 /usr/bin/java -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx500m -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -jar /usr/local/nagioslogserver/logstash/vendor/jar/jruby-complete-1.7.11.jar -I/usr/local/nagioslogserver/logstash/lib /usr/local/nagioslogserver/logstash/lib/logstash/runner.rb agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log -w 4
[root@localhost ~]#
[root@localhost ~]#
Are there any hints why logstash may be failing?
You will need to follow step 2 of the document as well.
tail /var/log/logstash/logstash.log2. Use setcap
the second option will preserve logstash running as the nagios user, however it should be pointed out that this method may be less
secure in some environments as it will allow any java process to listen on
privileged ports. To use this method, run the following
commands:
echo -e "\nsetcap 'cap_net_bind_service=+ep' \$(readlink -f \$(which java))" >> \
/etc/sysconfig/logstash
service logstash restart
The “Logstash is currently collecting” banner on the Admin Overview page may be briefly unavailable while logstash restarts.
root 4003 94.2 5.7 1388640 119020 ? SNl 16:34 0:13 /usr/bin/java -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx500m -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -jar /usr/local/nagioslogserver/logstash/vendor/jar/jruby-complete-1.7.11.jar -I/usr/local/nagioslogserver/logstash/lib /usr/local/nagioslogserver/logstash/lib/logstash/runner.rb agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log -w 4
[root@localhost ~]#
It stopped again.
[root@localhost ~]# tail /var/log/logstash/logstash.log
[root@localhost ~]#
tail produces nothing.
[root@localhost ~]#
It stopped again.
[root@localhost ~]#
