Export search results
vmesquita
Post by vmesquita »
Is there any way I could export the search results to a file? This could be useful to send to a support team, for instance.
Re: Export search results
This doesn't exist at this, however if your user has API access you can click the "i" icon upper right of the table to see how the data could be downloaded in JSON format.
