No Permission ti view information
marcolino7
Post by marcolino7 »
after a power outage, my nogios server do not shutdown properly. Since that moment I can access to web interface, but I cannot see Service, and webpage get back with this message:
It appears as though you do not have permission to view information for any of the services you requested...
If you believe this is an error, check the HTTP server authentication requirements for accessing this CGI
and check the authorization options in your CGI configuration file.
It workied fine until yesterday and, I changed nothing. I tried to upgrade to version 4.0.8 and I tried to ckek cgi.cfg and all seems to be fine. Apache is working fine.
Any help would be appreciated.
Marco
ssax
Dreams In Code
Re: No Permission ti view information
Post by ssax »
Are you using ndomod? Please post the last 100 or so lines from the following files:
/usr/local/nagios/var/nagios.log
/var/log/httpd/error_log
marcolino7
Hi saax,
thanks for answer.
Meanwhile I fixed the issue.
During power failure, i got a configuration file corrupted in apache. I don't know why, this line:
SetEnv REMOTE_USER REDIRECT_REMOTE_USER
became corrupted during power failure:
SetEnv REMOTE_USER=$REDIRECT_REMOTE_USER
So I fixed.
Many Thanks
ssax
Dreams In Code
Post by ssax »
That's great to hear, I'm glad you got that figured out. I will be marking this as resolved and locking the topic, feel free to create another if you run into any additional issues.
