Can not login nagios Xi web portal
Netxcel-ops
Post by Netxcel-ops »
Hi
I have a nagios server and i can not login the xi web. Wehn I type the username && password and click "Login" button and this windows display the login web again and doesn't display any error (like user or password incorrect).
Currently i can not see login username and password bar at all fter i reboot the nagios server, only can see the 3 repeat command as:
"Message: A database connection error has been detected, we are attempting to repair the server, if the repair does not resolve the issue, please contact Nagios support"
"Run the following from the CLI as root to attempt to repair the DB"
"/usr/local/nagiosxi/scripts/repair_databases.sh"
how can i fix the issues. Pls support!!!!
Re: Can not login nagios Xi web portal
Have you tried running the database repair script as suggested in the message?
In order to find out if mysqld is started, run:
service mysqld status
You can start/restart the mysqld service by running:
service mysqld start
or
service mysqld restart
To check for crashed database tables or other errors in the mysqld.log, run:
tail -20 /var/log/mysqld.log
You may need to run the repair script more than once to fix all errors.
Netxcel-ops
Hi Nagios Supports
Thanks for your support. I find the root cause for this issues.
There is no space in server hardisk and the process of mysqld can not start up. After i expand the disk size and this issues is solved.
Glad you got that sorted out!
I'll be closing this thread now, but feel free to open another if you need anything in the future!
